C450/C43 AMG
Turbo upgrade
Old Aug 7, 2024 | 10:35 PM
jimmykoutoulas's Avatar
C43
Turbo upgrade
Lots of talk around about turbo upgrades and HP numbers. So I will go about my build. Built by ECC Canada and tuned by Slav.G. Mods are spool performance intercooler along with there LPFP&HPFP. Carrillo rods and pistons custom made. Modalworks hybrid turbos. Downpipes, ECU TCU Dyno tune running on e50. Car put down 612/560 WHP.
Hot day and high DA will get better in the fall
Not to bad.
The 1/4 will improve as we are making adjustments to the tune. Car is shifting in auto at 6800 rpms and we are working on writing a tune to make the shifts point to 7100 and more boost out of the hole. We would like to run 10.3 10.4 on the street.
Old Aug 8, 2024 | 11:11 PM
TwoC400s's Avatar
2015 C400 4MATIC Palladium Silver Metallic
I'm sure the turbos from Modalworks gave you some added efficiency at higher boost pressure, but I ran out of fuel system long before I ran out of turbo.
I'm going to see how far the stock turbos and block can take me with a fully built fuel system first.
Old Aug 12, 2024 | 02:46 AM
hmcparland's Avatar
Mercedes SLC43
Same, I ran out of fuel also, using methanol injection with 75%methanol mix
