C63/C63S AMG
KM C63s ED1 Build
Old Aug 4, 2015 | 10:33 PM
  #51
Bespoke88's Avatar
bmw
Originally Posted by sabre1978
Yep, just checked, my bad. Not sure where I came up with 40 profiles must have been the caffeine, heroin and vodka cocktail for breakfast. Doesn't start the brain in the right way if you know what I mean... Apologies.
I wouldn't want to go any lower a profile than 35 tbh - not for some of our roads around where I live...
Based on the 20" rims and wheel specs above, I'll assume 285/35/19's is going to be no problem in the rear then. Also hoping 265/35/19s in the front will not be an issue. I'll have this all checked out though once I get the car.
@Kingmonkey - car looks awesome dude. Ring its neck!
If you run it off stock rim, it might be a tight fit you might get a little meatier tire look on that rim
Old Aug 4, 2015 | 11:22 PM
  #52
kingmonkey's Avatar
C63S ED1
Originally Posted by profi
How did you do the letter black out? Wrap or paint??
Painted small little letters took them an hour to put them on
Old Aug 10, 2015 | 01:52 PM
  #53
kingmonkey's Avatar
C63S ED1
Brace yourself's
Nutek upped the Ante they redesigned the wheels
Front Rim 20" x 9.5" Tires 255/30/20
Rear Rim 20" x 11" Tires. 305/25/20
Old Aug 10, 2015 | 01:59 PM
  #54
profi's Avatar
2015 C63s E1 Irridium silver, 2008 C300 rwd, 2007 Audi Q7 3.6 S line premium, 2002 Renault LagunaII
Originally Posted by kingmonkey
Brace yourself's
No rubbing?
Old Aug 10, 2015 | 02:09 PM
  #55
kingmonkey's Avatar
C63S ED1
No rubbing?
Nutek says no that those sizes will clear we will find out in 10 days !!
Old Aug 10, 2015 | 02:55 PM
  #56
Will617's Avatar
2016 C63S
Brace yourself's
Holy crap . If it fits/sits right it will look insane
Subscribed
Old Aug 10, 2015 | 03:28 PM
  #57
spacegeek's Avatar
Currently Looking
Subscribed
Wow is right. Since we're waiting 10 days I brought 2 bags.
Old Aug 10, 2015 | 03:29 PM
  #58
profi's Avatar
Will this void tires and rim protection plan? I mean any non Mercedes rims?
Old Aug 10, 2015 | 04:38 PM
  #59
kingmonkey's Avatar
C63S ED1
I changed the color to Gunmetal with red inners the car goes to sema Nutek wants to make a statement with the wheel sizes ,trying to get ADV1 ,Nutek was originally started from the owner of HRE .Nutek machines its own wheels like HRE so they have a fast turn around versus waiting 4-5 months for ADV1 who subs there rims out they have done my other cars with the wow factor!!
Old Aug 10, 2015 | 04:43 PM
  #60
kingmonkey's Avatar
C63S ED1
I'm sure it does JP check in?
Old Aug 10, 2015 | 04:53 PM
  #61
JPMBenz's Avatar
17 C63 S Coupe
Yes, aftermarket wheels are covered you would just have to pay the normal deductible. However, if you have suspension damaged caused by the wheels, MB will void the warranty.
Old Aug 10, 2015 | 06:31 PM
  #62
Bespoke88's Avatar
bmw
people were worried about rubbing with 285.. lol
not sure how these 305s are going to fit without hitting anything at all..
im guessing you wont lower and are you running different offset?
Old Aug 10, 2015 | 07:09 PM
  #63
RDOCA's Avatar
2016 C63S Sedan
Looking on the tire rack site the 305/25/20 are actually 0.3" smaller diameter than the stock tire so it should not be a problem there and if they can get a offset to clear the extra width it might work.
Old Aug 10, 2015 | 07:19 PM
  #64
Bespoke88's Avatar
bmw
I dont think I could run 25 with the roads where I am from probably 30 min
Old Aug 10, 2015 | 07:22 PM
  #65
RDOCA's Avatar
2016 C63S Sedan
Same here and I actually want to stay with a stock wheel to start and a 35 tire but a little larger width like 275 or 285.
Old Aug 10, 2015 | 07:25 PM
  #66
Bespoke88's Avatar
bmw
285 might be ok on stock
275 is ok for sure
Old Aug 10, 2015 | 10:06 PM
  #67
profi's Avatar
So with the 19 inch stock rim 255 front and 285 back would be ok??
Old Aug 10, 2015 | 11:16 PM
  #68
Bespoke88's Avatar
bmw
255 front yes
285 maybe
i would go with 275 if you want to be safe
Old Aug 11, 2015 | 12:12 AM
  #69
kingmonkey's Avatar
C63S ED1
255 front yes
285 maybe
285 will fit the rear with 19 or 20" the rear is very forgiving for larger size tires they tuck up and there is not much shock travel
Old Aug 11, 2015 | 12:14 AM
  #70
kingmonkey's Avatar
C63S ED1
True and thanks for checking
Old Aug 11, 2015 | 08:43 AM
  #71
Will617's Avatar
2016 C63S
Wheel needs to be 10" wide for 285"s. Scroll down on specs
http://www.tirerack.com/tires/tires....n&autoModClar=
Old Aug 11, 2015 | 08:47 AM
  #72
Will617's Avatar
2016 C63S
The diameter on those are a lot bigger plus the tires are a lot heavier.
The 25's are only 2 pounds heavier a piece. Curious to hear how much the Nuteks weigh. You want the tire/wheel combo to weigh as lil as possible otherwise it will slow the car down.
Old Aug 12, 2015 | 02:34 AM
  #73
kingmonkey's Avatar
C63S ED1
I will get the rim weight it's a forged 3 piece rim I'm sure it will weigh in a tad more I'm thinking the look will make the weight go away LOL
Old Aug 12, 2015 | 08:17 AM
  #74
Will617's Avatar
2016 C63S
Totally understand . It's a fine balance between looks and performance.
Old Aug 13, 2015 | 11:27 PM
  #75
kingmonkey's Avatar
C63S ED1
Centers getting ready to be machined!!!
