C63 Ride quality
Although the intent of the C63 was certainly not meant to be "practical" in terms of performance etc. etc., I was under the impression that it still would be comfortable to drive every day.
Heck, the people I know who own 911's and even the Carrera S are driving their's to work with little complaint. It seems hard for me to believe that the C63 (even with the performance pack) would be harsher than the Carrera S .
Although it's purely speculative at this point, from all that you folks have read, could the C63 actually be a less comfortable daily driver than a Carrera or similar.
Like everybody else here, I take what the journalists say with a grain of salt but I must say that I'm getting a bit worried since I am #2 on the waiting list here in Austin, TX and our roads are nothing like those in Germany.
Anybody have any thoughts on this?
swap the tires to +1
235/40 to 245/40
355/35 to 265/40 or wider if space is available.
the rims are 8" and 9" rears
yeah it may ride around like garbage when you are stuck on bad pavement and the tires will make it handle like a dog on carpet when it is cold.....but in the right moment when all the factors are aligned, nothing else will please, trust me!!!
p.s> comfort is relative to what you are used to. Some people find the SLK55 completely acceptable in terms of harshness. Having had a nother cushier vehicle (GL in the past and anticipating a S now) I would not want to be in the 55 for a highway trip for 3 hours on bad pavement.
"In the dry, on smooth roads, the C63 is magnificent. There’s decent steering weight and loads of information seaming through it. The suspension hunkers down to provide wonderful stability and big levels of confidence in high speed corners.
For all its inherent tautness, the ride is perfectly acceptable even on heavily pockmarked sections of bitumen, with excellent rebound control helping to quickly quell any nasty vertical movement. The front end is superbly damped, too, allowing the C63 to track faithfully without too much unsettling movement over bumps. Before long you find yourself making big demands on the chassis, marvelling at the directness and body control."
And all this from whom?
AUTOCAR!
http://www.autocar.co.uk/CarReviews/...63-AMG/226409/
MORAL?
Drive it yourself before passing judgment !
