C63 AMG (W204) 2008 - 2015
Aftermarket filters/removal of charcoal filters - softer VROOM when starting
Old Jul 22, 2008 | 10:52 AM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
Has anyone else done this and noticed that when you start your C63, the loud rumble of the exhaust isn't as loud as before?
I installed some VRP filters and also removed the charcoal filters, reflashed the ECU by my head tech, and started the car and it didn't have as loud of a Vroom as before. I drove it home and the throttle appears to be more responsive. I let the car sit for a couple of hours and started it again and same thing, the Vroom wasn't as loud. Doesn't really matter to me but was just wondering if other people experienced it
Old Jul 22, 2008 | 11:00 AM
Ruff's Avatar
2008 C63 AMG
I have replaced the filters and removed the charcoal filters and retained the stock ECU settings.
There is no change in the startup throttle blip, but I do get 1 mile per gallon better on the highway.
Old Jul 22, 2008 | 11:34 AM
gsrjc's Avatar
I should correctly say that my stock ECU settings are still there. My headtech just reflashed them back to stock ECU settings after he installed the filters.
Old Jul 22, 2008 | 04:16 PM
Hans Delbruck's Avatar
What I like!
In my experience, when the engine is warm it does not rev up as much when you start it.
Leave it overnight and see what happens in the morning.
Old Jul 22, 2008 | 04:48 PM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
I totally agree with Hans, it seems first thing in the morning you get a loud gurgle and popping on start up, when the car is warm it seems much more tamed....now i am thinking about putting air conditioning in my garage
Old Jul 22, 2008 | 04:51 PM
gsrjc's Avatar
Hmm, I'll try that and see. The engine was pretty warm yesterday because I drove it around a lot. Thanks.
Old Jul 22, 2008 | 05:04 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
That would be a nice addition to the **** Carpet....LOL
Old Jul 22, 2008 | 10:33 PM
chino1031's Avatar
2009 Mercedes Benz C63 AMG Arctic White PP
Ruff, you removed which charcoal filters ? the ones in the intake and the airbox ?
Old Jul 22, 2008 | 11:59 PM
Ruff's Avatar
2008 C63 AMG
When you take the cover off the air filter, there is a thin charcoal filter attached to the cover in plastic clips.
I removed just the charcoal filter from each side.
Old Jul 23, 2008 | 12:00 PM
chino1031's Avatar
gsrjc had told me that you also have to remove the ones from the intake as well. that didnt know you have to do as well. do i have to do that as well ?
Old Jul 23, 2008 | 12:14 PM
Ruff's Avatar
2008 C63 AMG
I'm not sure I follow you.
I am only aware of one set of Charcoal filters stacked in the air filter housing on each side.
Old Jul 23, 2008 | 12:19 PM
chino1031's Avatar
ok thanks. im waiting on my filters to have them put in there.
Old Jul 23, 2008 | 08:05 PM
gsrjc's Avatar
Yes, you replace the stock air filters with the aftermarket ones that you purchased. You should remove the charcoal ones too but nothing is put back in the intake system to replace the charcoal ones.
