tips on launching the c63 for the best quarter mile times
what are some of the members tips?
put it in S and just step on it when it turns green? or master M mode and do the same?
Anything with BOOST
At the dragstrip your going to want to stage the car properly by shutting off the ESP and by placing the car in 'S' mode. Powerbrake the car just prior to rear tires breaking traction. Once the last yellow bulb is lit, let it loose.
Even though burnouts in the box are crowd pleasers, as long as your on stock rubber I would suggest light burnout on the inside edge of the box (closest to the tree) and complete the burnout on the dryside. This will help you avoid bringing in water into the tires and up to the light. Stock tires aren't designed to need additional heat to provide maximum traction.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
a car without LSD can't really do much of a burnout anyway whether their on stock tires or not correct?
is it plausible to say that shifting perfectly in M mode can yield a better time than in S mode?
bike
Andy
Hope this helps.
Hope this helps.
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
no the sig is rite i was not looking when i wrote that its 12.476 im rele hoping to do like 12.2 next time i go. that run that i got 12.476 it was the last run of the day for me i had to leave so now i no what to do next time i go, and next time i go its ganna be 35 to 40 f so that should help me alot.
997TT, C63(delivered what a car!) ,M3 , WRX , A3
the question is...
why the car is so inconsistant?? is a bug from mercedes?
inconsistant and when you change in the paddle it takes like 1 hour to change. the change is fast,but the time to understand that you want another gear... welll what a LAG!... WHY??
CLK 500(Gone), C63 FTW!
