Question on painted amber reflector
2009 c63 white,2006 s4
Is it easy to install the painted amber reflector, what should i do with the bulbs inside the reflector if i take them out will an error occur???Thxthx
1 Post
2009 C63 AMG
There are a couple of links that give detailed instructions, but I deleted them as favorites. Search and you will find.
You can do them both from inside the hood, although it is tight for your arm. No errors.
2008 Black Out C350 Saks Edition / 87 VW GTI
Its very simple go to the W204 forum and do a search there are several threads with instruction and pictures, the bulbs you could painted or cover with foil paper
