C63 AMG (W204) 2008 - 2015
Washing Wheels
Old Sep 29, 2008 | 09:39 PM
stefario's Avatar
e550 4m
Washing Wheels
What is out there to help with the wheels, i had some spray i used to use on a set of racing hart i have on my G35 and with my pressure washer that thing would clean everypart of the wheel, inside and out. because of the spce between the rotor and the wheel you can see the build up pretty good. you an get your hand in some areas but not near the calipers - what is everyone else doing about this?
Old Sep 29, 2008 | 09:58 PM
HLG600's Avatar
2009 SL63 AMG
All you really need to effectively wash wheels is a bucket, dish washing detergent, a good wheel brush, and a pressure hose. Fill the bucket with a liberal amount of detergent and warm water. First blast the wheel with a stream of water, then coat every nook with generous layers of lather. Let it sit for a few minutes, then thoroughly rinse the wheel. Repeat for all four. Re-lather as necessary depending on how dirty the wheel is.
Here is the result!
Old Sep 29, 2008 | 10:26 PM
bigbodybeeenz's Avatar
bike
Just put 'em in the dishwasher.
Old Sep 30, 2008 | 02:49 AM
yooker's Avatar
a durr
negative on the dish washer detergent, i only use chemicals made for cleaning cars
Old Sep 30, 2008 | 02:54 AM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
Another caution, don't use the strong chemcial wheel cleaners because they're make other things in your wheel well get ugly. They are too strong.
Old Sep 30, 2008 | 08:27 AM
wonsuk_utmb's Avatar
2012 ML350 Bluetec
Those sl wheels are probably some of the easiest wheels to wash...
you could probably spit shine those.
Old Sep 30, 2008 | 08:38 AM
bumpnzx3's Avatar
W203 C230SS
meguiar's makes something called "hot wheels" or something like that. it's made for both painted, polished, and chrome wheels. i've used that stuff for years- it works really well. just don't use it on a hot wheel. spray it on and hose it off.
Old Sep 30, 2008 | 09:01 AM
Derspeed's Avatar
X3 and 2012 C coming soon
I'll second that if they are really dirty. Or you can use Eagle One All Wheel and Tire Cleaner. Never let it stay on the wheels for more than 60 seconds. I usually take my wheels off about every third wash and clean each entire wheel, tire, fender well and caliper. Then I use Wheel Wax on both sides of each wheel. After that, you should just be able to spray them off once a week and clean them with car wash soap that does not remove wax.
Old Sep 30, 2008 | 11:16 AM
Timeless's Avatar
2005 E55 ///AMG
I just use the same thing I wash the car with in a separate bucket. Gold Class car wash by Meguiars.
Old Sep 30, 2008 | 08:07 PM
Glock Guru's Avatar
Steel Gray 09' C63 AMG
I have good luck with the "Hot Wheels" also.
Old Sep 30, 2008 | 10:34 PM
stormkenny3's Avatar
clk 500 2003
again another vote for mequiar's hot wheels stuff. it is def worth a try and u will soon decide whether u like it or not.
Old Oct 1, 2008 | 03:01 PM
scottw's Avatar
2007 C230 Sport manual
For what it is worth, I just bought a refrigerator brush from Walmart for $3.50. It is perfect for getting between calipers and wheel. The brush looks like this. http://www.myfullerbrush.com/coil-brush.htm
Porsche sells a kit for about $60.00 but all you need is this brush and wheel cleaner, and a regular wheel brush.
Old Oct 2, 2008 | 01:16 PM
HLG600's Avatar
2009 SL63 AMG
On the more delicate paint job, I too would be wary of applying dishwasher detergent. But for cleaning off brake dust on clear coated wheels, the detergent does an excellent job.
