C63 Brakes (Non PP)
C63, BMW E46 M3
C63 Brakes (Non PP)
I own a E46 M3 and its brakes seem a hell of alot more responsive than the 6/4piston brakes on my 09 C63. The M feels like it stops on a dime, not so with my C63. It seems that I have to really press down hard to stop the car quickly. I wouldn't feel confident on a track with these brakes. Is this normal? The car only has 720 miles on it. I'm sure the dealer would tell me there is nothing wrong if I had them check the brakes.
BMWs have very quick brakes. I have owned a '97 M3 sedan and more recently a '07 335i. Each responded quickly to the slightest push on the pedal. I think the C63 has at least two things that do not work in it's favor: 1 . It's 4,000 LBS. 2. The brembo calipers and pads are less aggressive than those on your BMW. Just my opinion. What do you think?
a quarter mile at a time
IMO, the difference is pedal feel, not stopping power. Since the brake pedal travels a bit more and is boosted less, you get the sense that they aren't gripping. The brakes on the C63 are MUCH larger and much more capable than those found on the E46 M3.
I agree with everything you are saying. My point was to describe the aggressive "bite" of the BMW's brakes. There are dozens if not hundreds of brake pad compositions each with their own qualities and properties. The C63's must be less aggressive than those on his M3.
bike
I would have to agree. The brakes on my C63 seem to have less stopping power than the ones I had on my 330Ci. Seems strange since the brakes are almost twice as big
That was my point as well. Brake pads are about compromises. The BMW typical grabby brakes are notorious for their dust getting all over the wheels very quickly at that. I would think that the less aggressive pads on the C63 will produce less brake dust. Do you know of anyone offering alternative brake pads for the C63?
2009 C63 AMG / 2009 Nissan GT-R / 1988 Ferrari 328 / 1977 Maserati Bora
I owned both a E36 and an E46 M3. Different feel, but I don't think either of those cars would come to a halt quicker than my C63.
Has anyone used the C63 brakes in earnest when wet?
Pretty amazing stopping power. Instant compared to my old 2006 M3!
Its all easy in aperfect day and conditions! It's when you are in the crappola that these things matter!
the problem is not stopping distance at all but rather the fell you get from the brakes. ie. the distance you have to push the pedal. these cars when looking at all factors have a great stopping distance.
bike
Umm.. you guys do know that ceramic brakes actually are WORSE for stopping in normal usage right? You need to cook them up to temp before they really function.
I agree though, it's about "feel" not function. The car stops like mad, but what you're feeling is the inertia of 4000 pounds coming to a stop which shoves you forward and makes you feel like it didn't work as well as it should. Also the brake pedal feel is so so - i attribute that to rubber brake lines... anyone swap to braided lines and did the feel improve?
The reason your M brakes "feel" better is because they are over boosted to make up for the cheap one piston design. My 08 335i brakes are the same way. You should feel the oposite about the brakes. The M brakes arent track worthy, the AMG brakes are more than worthy. A couple laps on the track with the M brakes and they would be cooked. The AMG brakes are plenty big enough and with the massive 6 piston design is superior to the BMW design. Even BMW knows this. They are switching to Brembo next year and the brembos are already on the 135i.
I have had 3 911s two with Ceramics and I have driven the new M3 hard and the AMG is better than the M brakes.
C63, BMW E46 M3
Thanks for the replies.
I agree with you guys. It is the subjective feel that I guess is the difference. Objectively I couldn't tell which one was better but given the 6 piston brakes I would tend to think they would stop better than the E46 M3. It was just the feel I was referring to and am glad to hear it is just not my car. 300 miles to go before I can open her up! Can't wait.
PRETTY! SHINY!
No I meant any sort of CF in fact. Mostly yes, carbon ceramic, but the same is true - albeit requiring less warmup - with CF pads. I would suspect that is why the 030 rotors have slots - the slots create more scraping and friction. The cost is faster pad wear, but better pad surfuce and warmup time.
(flame suit on)
(flame suit on)
I agree about the feel of BMW brakes. Too much grab on initial bite, followed by a bit of pedal travel, then they firm up. You end up having to use a light touch, then increase pressure, just to get a smooth stop. The brakes on my Z4 M Coupe were difficult to modulate because of this. I think it was the result of aggressive pads and too much brake boost. Brembos are much easier to modulate but do not give that artificial feel of "grab" at initial pedal pressure.... they just provide steady, predictable braking power. It takes getting used to but it's great. The C63 is somewhere in between BMW and Brembo feel, IMO. Fwiw, my .01
The ones with the silver hub are iron and the ones with the black hub are the ceramics. I have the PP but no ceramics or alcantara. I wonder what happened with that and if MB would retro the ceramic rotors. My rear rotors are slotted
unlike the front rotors.
