Switched 12 volt power source
M5, C63, 335Ci
I'm sure I'm not the first C63 owner to hard wire their radar detector and laser jammer, but where is the easiest place to tap a switched 12 volt power source in the dash area? I was going to tap off the cigarette lighter, but I can't seem to get to the back of it and the front fuse block seems to only have always on sources. I did find some switched fuse slots in the trunk fuse panel, but I'd prefer to not have to run a wire from there to the front if I can avoid it.
Thanks,
Mike
Thanks,
Mike
