C63 AMG (W204) 2008 - 2015
Launch Advice
Old Jan 25, 2009 | 06:27 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
Launch Advice
Before I begin with performance upgrades, I plan to get some runs in with the car stock.(Keith if you have a track day planned let me know) My question pertains to launch tactics that have worked for others. My car does not have an LSD so I assume ESP off is out of the question. I will be using street tires considering they are just about slicks anyway.
Old Jan 25, 2009 | 06:35 PM
tyanger's Avatar
09 C63 steel grey
I'm curious about other peoples techniques too.
Lots of people say ESP-Sport with Sport setting, then either quickly roll onto WOT or just floor it WOT. I might just suck at it, but I still get lots of wheel spin this way, (but less than with ESP-Off)
Also, what tire pressures do you all use for stock wheels and tires?
Old Jan 25, 2009 | 08:07 PM
bazi 007's Avatar
c63 amg
whats wot?
Old Jan 25, 2009 | 08:34 PM
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
Originally Posted by bazi 007
whats wot?
Wide open throttle.
And I would say roll in to wide open throttle to avoid as much wheel spin as possible.
Old Jan 25, 2009 | 09:15 PM
mthis's Avatar
Anything W/4Wheels
1. do ecu reset
2. make sure you put your tire to about 26 psi
3.do a 5 sec burn out and make sure both your tires spining (i also dont have lsd) do this in M mode 1st gear.
while doing your 5 sec burn out when you let go of the breaks keep your foot on the gas and spin as you go.
STEP 3 VERY IMPORTANT.
4. line up and push u break all the way down and easy on the gas to about 2000rmp. hold ther till light goes green and then full smash.
IF YOU GET A BAD TIME THE 1ST RUN ITS OK. most likely your car will bog the 1st run doing what im saying to do. after your car wont bog no more.
also my friend has a c63 bone stock he ran a 12.201 at 114.xx same way.
thats how i got 12.2 and a bounch of 12.3 good luck.
p.s you can also do what i said in dyno mode if you like.
Old Jan 25, 2009 | 09:30 PM
Merc63's Avatar
C63 AMG
If you are in neutral and revving the engine can you pop it into first gear while doing this?
Old Jan 25, 2009 | 09:33 PM
mthis's Avatar
Anything W/4Wheels
this is a c63 not a honda civic even if you could i would not recomend this.
Old Jan 25, 2009 | 09:35 PM
mthis's Avatar
Anything W/4Wheels
you know what come this think of it i tryed in my bmw 545 and it dint work. it work up to 1500 rpm after it would lock and not let it go in to D. try it and let us know if it works lol
Old Jan 25, 2009 | 11:20 PM
wuyichao's Avatar
C63
lol, good luck with yoru car.
i have trouble launch my car too, too much wheel spin.
i usually ease on 1st gear and floor it at 2nd gear(and it still spins). 3rd and so on, i have no problem.
Old Jan 26, 2009 | 02:22 AM
bluejae's Avatar
'10 C63
Originally Posted by mthis
1. do ecu reset
would your steps be for esp sport or esp off? i don't have lsd either... how do you make sure both tires are spinning?
Old Jan 26, 2009 | 11:16 AM
tyanger's Avatar
09 C63 steel grey
What do you guys keep your tire pressures at for regular driving and street racing? The door panel says like 45 psi rear and 40 psi front. mthis said 26 psi for serious drag racing. I don't want to keep changing pressures every other day.
Also (off topic) - I guess because of the way I've been taking off from every red light, my rear tires will need to be replaced real soon - I'm at 2900 miles now. (I only seriously burnout about once a week though.)
Any thoughts on tires that are the best compromise between performance and durability?
Also if I want get 265 rears but the 235 fronts are still in good shape - is that going to be a problem with rid, performance, noise, etc?
(No more 'alsos')
Old Jan 26, 2009 | 01:46 PM
mthis's Avatar
Anything W/4Wheels
esp off or dyno mode. you can feel the car when both tires spin or when only one spins. if that dont work have smeone look and tell you.
*if you do a 1 wheel peal. go back to the water spot and wet your tires agin. i seen people break axel trying to do a burn out after stoped tryed to do agin and then snap.
Old Jan 26, 2009 | 01:50 PM
mthis's Avatar
Anything W/4Wheels
(No more 'alsos')
for regular i keep them at 36-38psi drag 26.
tires if you dont want to change the front. go with the same brand and make of tire perelli p zero 265/35/18 they make that. and they very good. if you want to go bigger the pilot sport2 are no joke. if you wanna get craxy like me mickey tom et2 and drive around. THE BEST
Old Jan 26, 2009 | 05:05 PM
Dads C63's Avatar
2014 Audi RS7
Howard,
I can't make the track on Wednesday but I am going to try to make it Friday. If you want to come out let me know. I can park mine and help you with yours if you want to race. Lets get hooked up and get you started racing!! Also, you are welcome to use my drag radials if you want to.
Old Jan 26, 2009 | 07:13 PM
hhughes1's Avatar
Friday will work great. I assume Speed World in Bithlo is the place ....you let me know what time.
Old Jan 26, 2009 | 08:36 PM
xxx_C63AMG_xxx's Avatar
C63 AMG
mthis?
How do you do an ECU reset?
Are you suggesting that the C63 has some sort of launch control?
does this only work with ESP off, or will it work with ESP sport also?
Old Jan 26, 2009 | 08:41 PM
mthis's Avatar
Anything W/4Wheels
Originally Posted by xxx_C63AMG_xxx
mthis?
ok ecu reset.
1.get in car and close all doors.
2.before you do anything else keep your foot on the gas all the way down.
3.out key in pos.3 dont start the car.(while holding the gas down, hold the gas down for 10 sec with the key in pos.3 then shut off car while holding the gas down and DONT TAKE THE KEY OUT. one you turn key to pos.0 let the gas go. now just stay in your car for 2 min with out touching anything and you good to go.
good luck.
oh if you get tration with esp sport fine it will work. i have 2 friend that have c63. one of them swears ok esp sport that its the best me and the other one hate it.
Old Jan 27, 2009 | 05:26 AM
6.3CAMG's Avatar
Mercedes C63 AMG
ok ecu reset.
good luck.
but what effects does the ecu reset have ??? and whats this about launch control??
Old Jan 28, 2009 | 12:30 AM
mthis's Avatar
Anything W/4Wheels
ther is NO launch control we the drive make that our selfs.
the ecu reset all it does is it takes everything to factory shift points. not to how you drive it. it will reset driving style of your car.
the easy way to do this is get a MHP tune they take care off 90% or more of this problem. anyone plese feel free to correct me if im wrong .
Old Jan 28, 2009 | 07:55 PM
benscott01's Avatar
STS, Tahoe, Suzuki, and C63
Howard, are you still wanting to go to the track Friday night?
Old Jan 28, 2009 | 09:14 PM
hhughes1's Avatar
That's the plan right now, weather permiting
Old Jan 28, 2009 | 10:41 PM
peet's Avatar
09 C63
BTW: LSD has NO impact on a straight line launch. That is unless your track has oil on the one side where one tire runs. It only has benefit on multi mu surfaces OR cornering.
Old Jan 28, 2009 | 11:49 PM
mthis's Avatar
Anything W/4Wheels
not true.
i had my car spin 1 wheel after the 60 foot mark.
that slows you down.
anyway, what ever kind or racing you doing wheel spin loses time. the people that you see drifting while driving aound a track they just trying to be cool. if you ever watch any videos of people trying to get the best time they try the best not to slide or spin the tires.
