Coolant level
C63, BMW E46 M3
Coolant level
Coolant level msg came on today. Fluid level is about 2 finger breadths below fill mark. Dealer says just ot add water. I asked him if it is recommended to use distilled water he replied no. He said something about the coolant having a 15 yr life and that I am only replacing the water that has evaporated and something about the coolant contracting in the cold. It was about 50 degrees in my car last night so not very cold. Should I just add water and if so distilled, tap etc. Or do I add coolant. If I bring it in to them they will just add water according to him.
Thanks.
Thanks.
2010 C63
Distilled water costs, what, $1.29 a gallon. Use distilled water -- tap water is probably fine, but it does contain chlorine, flouride and other stuff that probably is not great for your engine. If it is a one-time thing, it doesn't matter what you add, but if you need to add every couple of months, then you should alternate between adding distilled water and coolant. You could also mix distilled water and M-B coolant into a storage container and use that.
Also, I would NEVER leave ANY fluid inside a vehicle for 15 years. "Lifetime fill" is a self-fulfilling prophesy.
C63, BMW E46 M3
Anyway ,thanks guys.
