C63 AMG (W204) 2008 - 2015
MHP Stage 2 Dyno Results!
Old Mar 11, 2009 | 06:52 AM
sprins's Avatar
G55, SLS, smart eq
Originally Posted by YNOT600
Question: Since 5th gear is 1:1, why do other tuners dyno in 4th?
Dyno in 4th is done on the 5-speed automatic (1:1) and 5th should be done on the 7-speed automatic (1:1).
Old Mar 11, 2009 | 08:01 AM
MHP's Avatar
MHP
'09 C63 AMG
We agree, and have said as much about both trannys in the past (4th with a WA5A, 5th with a 7G) 1:1 is by far the best/most accurate way to test on the dyno.
Old Mar 11, 2009 | 08:09 AM
Dads C63's Avatar
2014 Audi RS7
On a stock C63 you cannot dyno in 5th because of the speed limiter. You are forced to dyno in 4th. The top of 5th(1:1) gear is 186mph and none of the limiters will allow you to reach that point. The stock limiter is 155, option 251 Delimitation of top speed is 174mph, therefore unless you have a tune that totally eliminates the top speed you cannot complete a 5th gear dyno pull. Good luck!
Old Mar 11, 2009 | 09:02 AM
MHP's Avatar
MHP
'09 C63 AMG
Keith is 100% correct. 5th is still the way it should be done but most can't until after a tune.
Old Mar 11, 2009 | 09:20 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Originally Posted by MHP
MRAM, I should be back in the country in 7-10 days (maybe a bit longer) so if you want please PM or email me your phone number. I would be more than happy to personally discuss with you anything that you have even a shadow of a doubt about. I promise you that any reservations you may have will no longer be present post discussion.
Thanks!
Andy
Fair enough
Have a safe flight
See yeah
Old Mar 11, 2009 | 01:02 PM
-michael-'s Avatar
2009 MB C63 2007 MB ML63 2006 MB CLS 500 (wife)
Also to my knowledge no one else does 63 TCUs or part throttle, nor have they for the past year or more as we've been doing
Thanks!
Andy
I'm really sorry and I'm not trying to prove anyone wrong. Actually I'm a fan of MHP but I think there is a company that does "TCU upgrades for all models" (quote from the company site ) I think that includes 63 series since they offer an ECU tune as well.
http://www.veloceperformance.com/mercedes.htm
As someone said already "Never hurts to be an informed consumer" so that's what I'm trying to be.
PS Guys at MHP Please don't get me wrong. I'm just sharing some info.
Old Mar 11, 2009 | 02:43 PM
  #32
MB_Forever's Avatar
E63 P30, CL500 Sport
Keith, I completely understand why stock C63s are being dynoed in 4th gear, but what I do not understand is why do other "tuners" still continue to dyno in 4th gear. All tuners should be able to delimit the car to 186 mph or higher. And since 5th gear is the only 1:1 gear, which yields the most accurate results, then all tuners should really dyno in 5th gear This would at least make the comparisons much easier.
Old Mar 11, 2009 | 02:44 PM
  #33
MB_Forever's Avatar
Andy, what cars are you tuning in Dubai?
Old Mar 11, 2009 | 02:58 PM
  #34
Dads C63's Avatar
2014 Audi RS7
MB Forever,
I believe most continue to dyno in 4th because that keeps the comparisons fair for those that can't dyno in 5th. In order for me to compare my stock dyno to any new one I have to run 4th because the stock dyno was in 4th. Not trying to muddy the waters just thinking from my own point of view. Just thinking out loud.
5th gear is a true 1:1 but it takes much longer which puts more strain on the engine and runs the dyno's to a much greater speed. Just my 2 cents worth.
If we could all dyno in 5th then I'm sure we would.
Old Mar 11, 2009 | 03:19 PM
  #35
DFW01E55's Avatar
'14 ML BT
Sounds like you're asking for their permission or forgiveness.
Are they holding a family member hostage?
Old Mar 11, 2009 | 04:00 PM
  #36
-michael-'s Avatar
I was just trying to be polite.
Old Mar 11, 2009 | 04:30 PM
  #37
dlbello's Avatar
2009 C63 AMG Black on Black PP Package CF fully loaded
Nice find... thanks
Old Mar 11, 2009 | 04:46 PM
  #38
DFW01E55's Avatar
'14 ML BT
This is the interwebs!
You will be attacked for being polite!
Old Mar 11, 2009 | 04:53 PM
  #39
SebringSilver's Avatar
R8
Not at all. For point of reference (and I'm not saying anything bad about MKB because I think they have solid products) but you could pay $14,700 for their stage 2 ECU (no part thorttle or TCU) and shorty headers that require cutting/welding or thousands less for our Stage 2 package which includes:
v3 ECU/TCU (search for "Stefario"s results from his independant dyno of our software on his stock c63, vid on youtube), Carbonio CF airboxes/high flow filters, 180F Thermostat, Thermalnator intake gaskets, and SS longtube headers with high velcoity merge collectors with or without catted mids that bolt up directly and mate with the factory catback or our own race catback.
Please contact me via email with any specific questions. Our new website will be up soon and will include all pricing, info on all our packages (next up stall converter, and H/C).
Andy
Okay, thanks.
Old Mar 11, 2009 | 05:25 PM
  #40
BerBer63's Avatar
2009 C63
MB Forever,
Do you do this in S-Mode just switch it to 4th gear and step on it till the car switches gears to 5th or in M-mode and just change gear/let off at the limiter?
Old Mar 11, 2009 | 05:40 PM
  #41
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I think most 63'ers dyno in M mode...
Old Mar 11, 2009 | 06:11 PM
  #42
MHP's Avatar
MHP
'09 C63 AMG
You're fine brother. I'm not going to comment reg. other vendors anymore, but I will state again that we're the only ones doing 63 TCUs (that work).
Old Mar 11, 2009 | 06:17 PM
  #43
MHP's Avatar
MHP
'09 C63 AMG
FYI, a 6.2L motor with 40mm intake valves/33mm exhaust valves and heads that flow over 400cfm intake/300cfm exhaust at .500" lift with the stock cam specs (we cam doctored them) needs 1 7/8" primaries and a full 3" exhaust for optimal performance. That's why as you'll note, we make more power and torque across the board. Anyone that says otherwise (about larger diameter tubing) has obviously never fabricated an exhaust system.
Andy
Old Mar 11, 2009 | 06:36 PM
  #44
mthis's Avatar
Anything W/4Wheels
you back halla, whats going on andy how's work in dubai doing?
Old Mar 11, 2009 | 06:59 PM
  #45
MHP's Avatar
MHP
'09 C63 AMG
Unhappy
Whassup Hagi! Going well, list of cars is incredible. Lots of videos/pics to post when I get back. The keep bringing in more cars so we keep bumping back our return date.
Old Mar 11, 2009 | 07:06 PM
  #46
MHP's Avatar
MHP
'09 C63 AMG
Mo,
We're presently in Abu Dhabi.
63s, 65s, 911 GT2s, Carrera GT, Scuderia, F430s, LP640s, Gallardo 560 superleggas, Veyron (maybe one more before we leave), BMW M5/M6s, the new X6s, Bentley W12s, Range Rovers, Infiniti FX50s, G37s, Lexus 570s with TRD blowers, Infiniti Q56s, Nissan Patrols (SUV with 4.8L I6 and a turbo, some have 1500hp), Z06s, SRT8s, Vipers, etc.
The market here is every car guys wet dream, lol.
Andy
Old Mar 11, 2009 | 07:22 PM
  #47
mthis's Avatar
Anything W/4Wheels
you are so lucky to be there with all does cars. good luck stay as much as you can when u get back here they ganna be gone. ohh yea do some 360 in the veron for me
Old Mar 11, 2009 | 10:22 PM
  #48
zivicirl's Avatar
C63
Are my calculations correct?
462RWHP = aprox. 563 Engine HP?
Old Mar 12, 2009 | 03:17 AM
  #49
MHP's Avatar
MHP
'09 C63 AMG
Will do brother!
That is correct.
Andy
