C63 AMG (W204) 2008 - 2015
Bluetooth PassKey
Old May 17, 2009 | 12:43 PM
esport's Avatar
08' S550,,,C63!
Bluetooth PassKey
I need some help. I forgot the MB Bluetooth passkey and I would like to know if it is the same on all cars if not where can I find it.
Old May 17, 2009 | 12:45 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
You make your own. Car prompts for a number. You enter any number you want. Then the phone prompts for a number and your enter the same number that you made up for the car. Works for my iPhone.
Delete your phone and re-associate it with any number you want.
If I've misunderstood your question then apologies.
Old May 17, 2009 | 01:25 PM
451/443=EW's Avatar
C350 4Matic
+1, just delete your phone from the car and the car from the phone. Then just start over again, its very easy and make up a new code, like 1234 or 0000 or what ever. you will need to put the same code in the phone as you do in the car and it done.
Old May 17, 2009 | 01:32 PM
esport's Avatar
08' S550,,,C63!
I thought it was this way but apparently its not working its says device not compnatible its a Blackberry storm?
Old May 17, 2009 | 01:35 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Have you deleted the phone from the car and deleted the car from your phone and then re-associated from scratch. I've had to do this and it works. Good luck.
Old May 17, 2009 | 01:58 PM
esport's Avatar
08' S550,,,C63!
Yup and even did a reboot and nothing. I changed my phone from a Bold to a Storm and it works on my other cars expect the C63 its saying not compatible but the wierd part is the phone is asking me for a passkey but not the car. I thought both units would ask for a code.
Old May 17, 2009 | 02:08 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
COMAND owner's manual page 99 says you can do the association backwards ergo phone first. Enter a number on the phone then the car should prompt a passkey and enter that same number.
Old May 17, 2009 | 02:18 PM
esport's Avatar
08' S550,,,C63!
Thanks I will retry it again. lets see!
Old May 17, 2009 | 03:26 PM
Ape's Avatar
Ape
2004 TL; 2004 S2000; 2009 C63; 2009 ML350
When I was having problems with my BB the dealer told me to use pass-code "MBUSA" using the corresponding numbers on the phone (don't have a phone in front of me or I would give you the numbers that correspond to the "MBUSA" phrase.
Old May 17, 2009 | 03:38 PM
dps01's Avatar
2009 C63 AMG
+1
My BB wouldn't let me set my own. I had to use "MBUSA" as well.
Old May 17, 2009 | 07:42 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Did you get it working Esport?
Old May 18, 2009 | 04:28 PM
esport's Avatar
08' S550,,,C63!
Actually I did after a reset and then went into the system and works perfectly. thanks
