CLK63 Black Series Wheels?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Sorry for starting yet another wheel/tire thread but I am curious to know if the C63 can fit stock CLK63 Black Series wheels?
Stock CLK63 Black Series wheels
Front: 265/30R19 with 9.0x19 wheel and 25mm offset
Rear : 285/30R19 with 9.5x19 wheel with 31mm offset
Stock C63
Front: 235/40R18 with 8.5x18 wheel with 45mm offset
Rear : 255/35R18 with 9.0x18 wheel with 54mm offset
I've used this internet wheel offset/tire diameter calculator (http://www.bigcustomwheels.com/info_specs.jsp) to see the visual difference between the two and here are the results
Front:Wheel will stick outward 35 mm (1.4'') farther than stock.
Rear: Wheel will stick outward 38 mm (1.5'') farther than stock and will fill the wheel well by 10mm.
Just wondering if there is enough room in the tiny wheel wells/fender area of the C63 to fit these wheels without additional modifications such as fender rolling.
Stock C63
c63 AMG, BMW 335 conv
There is no hope these wheels will fit.
I tried 19x9.5 45 offset with 275/30/19 on the rear and it touched the outer lip. So there is no way they will fit.
