C63 AMG (W204) 2008 - 2015
Throttle/ECU reset trick help
Old Oct 23, 2009 | 07:53 PM
desmo996's Avatar
BMW 335i, Ducati 996, Mercedes C63 AMG
I did a search on the procedure but there are some variations in the instructions and I just want to make sure I do it correctly. Can someone who has done it with success list the steps again?
Old Oct 23, 2009 | 08:03 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Why repeat if you already STFF'd. Did you not notice a change?
Old Oct 23, 2009 | 08:22 PM
desmo996's Avatar
The instructions posted varied regarding exactly when to press the accelerator down, when to take your foot off, how long to wait after the process, whether to get out of the car and lock the doors and wait 2 minutes, etc......
Just wanted some clarification from someone who has done it correctly before.
Old Oct 24, 2009 | 01:49 AM
C63 DTM AMG's Avatar
Radio Flyer Big Flyer fully loaded with training wheels and NOS
take a look at the beginning of this thread
https://mbworld.org/forums/c-class-w...ts-thread.html
Old Oct 24, 2009 | 12:43 PM
desmo996's Avatar
Looks good, thanks for the link.
Old Oct 24, 2009 | 12:54 PM
no problem
Old Oct 24, 2009 | 01:32 PM
dremorg's Avatar
2015 Jaguar F-Type R Coupe' '99' Audi A4 Avant Quattro 2.8 DD
no problem
Have you done it & if so, can u feel a difference?
Old Oct 24, 2009 | 02:14 PM
actually i have...i do it about every few weeks when i leave the city and head up through CT and NY in order to get rid of the "stop and go" city driving and have a "clean slate" for the transmission. I reset it then do some sprinted runs and hard driving and i can feel a world of a difference.
Old Oct 24, 2009 | 10:57 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
do you really feel a difference or do you just think that you do. Placebo affect by thinking that this reset is doing something.
Old Oct 24, 2009 | 11:05 PM
can you read? i said i felt a difference because the ecu in my case went from stop and go city driving to WOT country driving...so in my case i actually felt a difference like i said before
Old Oct 25, 2009 | 10:54 PM
gsrjc's Avatar
and did you read what I wrote... placebo effect as the Butt Dyno as people have reported is a crock. If you really think there is a difference, prove it on the dyno or at the track. i'd really like to see how the car runs in the quarter mile if someone has driven stop and go and then compare it to the times after you do WOT at the track.
Old Oct 26, 2009 | 02:38 AM
ATKM5's Avatar
2005 Mercedes G55 AMG
Hmmm, I`ll give it a try again. People in the E63 section say that this ECU reset trick only works on 5-Speed auto trans. 7g Tronic cannot be reset using those steps. They said the only way to do it is to disconnect the battery overnight... I did that a few times and it works great!
Old Oct 26, 2009 | 12:01 PM
ive disconnected the battery as well...after i reset it using the steps provided, i hear a "whirring" noise from the engine bay. the battery works just as well in my opinion. im just stating what ive experienced
Old Oct 26, 2009 | 02:23 PM
ATKM5's Avatar
Yeh, I hear the same noise as well...
The car runs much better with the TCU reset!
Old Oct 26, 2009 | 02:32 PM
sflgator's Avatar
'09 C63 AMG
Disconnecting your battery will also erase all Sirius-XM Sat radio presets and such...which is a real PITA, imho. I would try the TCU Reset "trick" before disconnecting the battery.
Old Oct 26, 2009 | 08:27 PM
GermanCars's Avatar
2020 E450 Wagon
You are going to cause yourself and the poor tech that works on your car a lot of grief if you continue to disconnect the battery just to reset the Trans adaptation. The car is going to be full of undervoltage and communication fault codes. I have seen as many as 5 or more pages of fault codes set in various modules/control units when doing full scan with our SDS diagnostic computer after a dead battery replacement. How is a tech supposed to diagnose a electrical/computer problem when the issue is masked with fault codes set where there isn't a problem?
Old Nov 3, 2009 | 02:41 PM
peet's Avatar
09 C63
That whirring noise is the sound of your dampers closing - nothing to do with any resets. Think about it - when was the last time an IC board made whirring sounds (when it doesn't have fans or other mechanical whirlygigs).
