C63 AMG (W204) 2008 - 2015
wheels
Old Oct 27, 2009 | 09:24 PM
ChrisD63's Avatar
2009 040 Black C63, 2009 Arctic White G55, 2012 Storm Red CLS550 4Matic
wheels
are the front and rear oem 18" c63 rims the same size?
Old Oct 27, 2009 | 09:31 PM
Sincity's Avatar
No. Fronts are 8" and rears are 9".
Old Oct 28, 2009 | 12:02 AM
Jae Duk's Avatar
'09 C63
I thought they were 8.5 and 9.5?
Old Oct 28, 2009 | 02:23 PM
Even Money's Avatar
'15 VW GTI
Not to be a smart a**, but it's in the manual. Although, when I get new rims soon, I'm going with 18, 8.5 and 9.5 w/ 245, 275.
Old Oct 28, 2009 | 07:46 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
We could only wish the rears were 9.5 Several tire manufacturers make 295 width extreme performance tires that spec on a 9.5 rim as the minimum.
Old Oct 28, 2009 | 09:31 PM
dlbello's Avatar
2009 C63 AMG Black on Black PP Package CF fully loaded
Why not go with 19, 8.5 and 9.5 ?
Old Oct 28, 2009 | 10:43 PM
Even Money's Avatar
'15 VW GTI
I thought a long time about it...IMHO, I didn't want a slimmer sidewall with the 19s. Plus, I want the lightest rims possible for rotating mass reduction. Also, 19" tires are more expensive.
Trying to stay relatively close to the stock diameter, if you were to run 19s in the back you would need at least 285/30(to avoid a slim sidewall), which I think will cause rubbing issues, especially at high cornering loads. I can barely fit my fingers between the rear tires and the inner fender well as it is.
Lastly, I think 18s will track better than 19s. And the rubber band look that 19s will give with the slim sidewalls....I don't like.
