C63 AMG Calrsson Parts
Door pins are very easy to install. You just need to unlock your vehicle, then the original OEM pins need to be unscrewed. If you have any questions, feel free to email or give us a call.
From what I understand, after reading several door pin threads in the w204 forum, you cannot simply unscrew the rears. I'll hold for a GB on the Carlsson pins instead of the Brabus ones.
#33
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Not true for the rears. Fronts are screw in, rears are ball-socket design. From the pictures, looks similar to the Brabus design, which means they're just caps to go over the thinner upper section of the rear pins. When locked, you'll see the full extent of the carlsson pin, but when unlocked, you'll see the OEM pin exposed under the cap.
#34
