BRABUS DOOR PINS - 10 SET SPECIAL
Would like to run a weekend special to the members, set of 4 Brabus door pins, $125 shipped in the continental USA. CA residents must add tax to the price, international buyers please email/PM me for shipping rate.
Here is a picture as requested. All you have to do is unlock the vehicle and unscrew the OEM ones, then install these. Pretty straightforward install. These are W204 specific. No problem Sincity.
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
The Brabus 204 pins should have one pair longer with screw threads inside, and one pair shorter and wider which are caps. If the ones you carry are all 4 the same size and screw, then you're carrying the 203 pins. Brabus misprinted their part number 203-819-00 for their 204 price sheet. It really should be 204-819-00.
https://mbworld.org/forums/attachmen...rice_guide.pdf
You can cap it over the existing rear pins, but sticks out and doesn't cap all the way down. To remedy this, you have to pull off the rear cap (basically break it), then use some sort of pressure tube or rubber cement to fill out the rear cap and hold to the exposed inner pin.
According to the price sheet from Brabus that Azn_300 supplied, it lists the pins at $125 a set. So the GB savings is in shipping? Or is the price sheet that Azn_300 supplied is outdated? I hope this is a mistake like what was posted in the GB for the KLEEMANN K1 tune that OP posted.
For the rears, instead of pulling the stock pin off, can't you simply trim a little bit of the top off (with a dremel tool) and then slide the new cap on?
