Aftermarket wheel Thread.
#1101
1 Post
M5, C63, 335Ci
Considering PUR 4OUR in black 19 monoblocks for my 2012 Diamond White C63 Coupe 275 rear, 245 front. The pics are of CLSs. More pics in the link below
http://www.purwheels.com/portfolio/m.../mercedes-cls/
![](http://www.modularewheels.com/wb/wheelRequests/1352729356142.png)
#1103
2009 C63 ///Amg
Hey Guys,
After a decent amount of problems with my current set up, ADV.1 is being kind enough to make me new centers for my wheels, can someone chime in with a known offset for a 20x10 wheel with a 285/25/20 tire that does not rub? Whether it be on coilovers or without
would be greatly appreciated!
Thanks for your time!
J Bro
J Bro
#1104
hey guys, after owning a couple m3's, decided to go with the c63 coupe this time....car is reaching the port on 11/21, so I should have it towards the end of the month. your cars all look amazing, I am really liking the HRE C93's, P40's and M47's (preferably in black with a chrome lip as the car is polar white with the black roof).
Any major issues with staggered 20" HRE C93's, P40's or M47's? Did you have to modify the wheel well or body to fit these wheels? Appreciate any help.
I think I read there is another member/sponsor on this site who can get HRE's at discounted rates and is well versed on their compatibility with the various MB's..is this still the case?
#1105
Jbro, u can go 20x10 +55mm (or higher) with 285/25/20, but I would stick with 275/25/20 if u want zero rubbing.
M3equals333, welcome to the forum! U will love ur torque monster. Lol As for ur wheels, u can definitely do 20's staggered with HRE.. Just PM Lon@HRE, he cam custom make a wheel combo to ur liking (color & sizing wise).
#1109
M3equals333, thanks for the kind words! Which models HRE have you chosen?
BerBer63, you definitely needs longer lugs with the 5mm spacers. Have you tried contacting a vendor here like Vivid, Wheel Boutique or ACG?
#1110
#1111
I couldnt get enough turns with the oem bolts with 5m spacers. You can use 35mm bolts in the front and rear. If you're paranoid you can also get the Bolts cut down to 32mm
#1113
18x9.5 offset 54
285/30 nitto 555r
Almost 1 inch drop with coilovers
Turning out to be a pain in the ***. Going to try it without any spacers, then I'll look for 32/33mm bolts.
#1116
I tried my 37 or 38mm bolts (ones I use with 10mm spacers) on my 5mm spacer setup right now and just rolling in my driveway I think I can hear the bolts hitting the emergency brake (metal clickling/clanging).
18x9.5 offset 54
285/30 nitto 555r
18x9.5 offset 54
285/30 nitto 555r
I was unable to find 33/32mm bolts. I ended up cutting a set of 40mm bolts down to 32mm. 35mm will also work as that's the length of my locking bolt. it clears the front as well without spacers.
#1117
new wheels for the coupe
will take better pictures once they arrive and are fitted to my car (which arrives in Jan 13) but looking pretty awesome ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
going onto a tenorite grey coupe, 19 x 8.5 and 19 x 10, brushed black tint lip with gun metal interior
#1118
Has anyone used spacers with stock rims and no drop? I've been wanting to do it but Im not sure how it will look. I want the wheels to sit flush, what do you guys recommend? 5mm or 10mm?
#1120
Does anyone know if HRE P43S 20x9 & 20x10.5 (offset 29 front 45 rear) would fit on a 13 c63 coupe?
also, does the c63 coupe share the same trunk as the w204 c63 sedan?
your help is greatly appreciated.
thanks,
derek
thanks,
derek
#1121
I heard the sedan trunk is different from the coupe trunk.
As for the HRE wheels, no way you can fit 20x9 +29mm & 20x10.5 +45mm unless you run tiny stretched tires or raise your car. LOL
#1122
#1123
Vivid Racing '09 C63 AMG
Here's my setup on H&R coilovers...and I have a little bit of rubbing with 245/30/20, 285/25/20. Might raise my suspension 1/2 inch.
Front 20x8.5 +35
Rear 20x9.5 +51
![](https://mbworld.org/forums/attachments/c63-amg-w204/247707d1353544232-c63-20-wheels-please-post-your-pics-image.jpg)
Front 20x8.5 +35
Rear 20x9.5 +51
![](https://mbworld.org/forums/attachments/c63-amg-w204/247708d1353544321-c63-20-wheels-please-post-your-pics-image.jpg)
