Aftermarket wheel Thread.
#2376
SPONSOR
www.wheelsboutique.com
I've been looking around the forums and online in general and it seems we are kinda limited. I'm switching over from the JDM 5x114.3 which literaly has endless options.
I wanted 19x9 +35 squared on Rotiform SNA's but they have been discontinued😢. Essentially what I'm gathering is the W204 can accept a 19x8.5 +35ish up front and be flush? Is anyone running a 19x9.5 up front? I'm really trying to run a square setup for rotational purposes. If I can't I'm probably gonna run a 19x8.5 square and use some spacers in the rear to get it to fill out.
If you opt for the forged version of the SNA then Rotiform will make you any size & width you'd like. Same goes for HRE & Adv
.1.
#2378
SPONSOR
If you're looking to keep costs down then the 3-piece SNA would be your best bet. Within Rotiform's pricing structure a 3-piece is the most cost friendly configuration - then comes the 2-piece then the Monoblock. I'll PM you with preliminary pricing.
#2379
#2380
Kriston (05-25-2016)
#2382
Hi -
I know it was a long time ago, but I would really appreciate some help from you if possible. I got my eyes on this vertini as well, what is the set up of yours? I have a 2012 coupe factory suspension, just want to have a tire fender flush as well as a wider than factory rear tire(hoping for 265). Were you able to get Michelin PSS for your wheels? I noticed you had hankook on instead.
Thank you!
#2383
2014 C300 Sport
Hi -
Thank you!
Thank you!
#2384
I am looking at some 18" aftermarket wheels for my 2011 C63. I'm sticking with the stock tires sizes, 235/40-18 front and 255/35-18 rear. I really like the Rotary Forged TSW Bathurst wheels. They come in 18 x 8.5 +43 offset in the front and 18 x 9.5 +40 offset for the rear. I'm a little concerned about the rears, will the clear without rubbing?
Thanks,
Glenn
Thanks,
Glenn
#2385
Thanks,
Glenn
Thanks,
Glenn
#2386
Well I can tell you that I have a 9.5 width rear with a +47 and 265 tire I think it's perfect and I would not want it anymore aggressive it's compleatly flush with the fender no rubber. A +40 seems wayyyy to aggressive for the rear for how my car looks. I wouldn't unless you wanted to stretch the rear tire. Not a fan of that though. The front I have a 8.5 width with a +37 and stock tire size I feel like it could stick out more maybe +32 even there is room. The et you want def won't be aggressively flush for the front but obviously will fit no problem no rubbing
I am so close in the rear. I will be 7mm more out than you are, but I will run the 255 tire which will be around 5mm in. So overall 2mm further out for a measly .08". So do you have more than a tenth of an inch clearance in the back? Problem is, I've had tire rub issues on another car in the past and it's just no fun! I wonder if I can get someone to machine off 7mm off the face of the wheel? I hate to play with that because it could affect the wheel strength.
#2387
#2388
I'm thinking of going to Discount Tire, tell them to get these wheels and if they clear I will buy them. That way I don't take the risk of having to return them.
EDIT: I found a place here in Arizona that can machine the offset. They also sell wheels, so I've sent them an email asking if they can increase the offset on the rears from 40 to 47. Also, with the 8.5" wide wheel and 43 offset in the fronts, the inside clearance will reduce by 4mm. How is inside clearance on the fronts? I assume this will be OK???
#2389
If you shave the hubs remember you still have to clear the brakes. You might be able to shave a few mm off the hub but 7mm seems like it might be too much.
You are better off to find wheels that fit out of the box.
#2390
Mort, thanks for the info, you are absolutely correct. The good news is we can look at that before we shave any off. I actually think they may work without shaving, they will just be flush, but I may still shave a few mm's off just to be safe.
#2391
Can anyone tell me if this will work on a sedan without fender work on the rear
20" x 10.5" et42?
If so what tyre size would work 285? 275?
20" x 10.5" et42?
#2392
Max you can run is 19x10 +50 on a 275/30/19
ADV1 specs 19x10.5 +52 I believe, but they recommend it only with a 265/30/19, and it'll rub under a full load a little bit.
You can run 285s if you size up to 20s.
20x10 +50 on a 285/25/20 would also be ok.
#2394
So the best without arch work on the rear would be 20x10 et50 285/25/20
What about the front?
HRE_Jurrian (08-02-2016)
#2396
Former Vendor of MBWorld
#2398
