Problems with Headlights and H.I.D. Fogs
2009 Mercedes Benz C63 AMG Arctic White PP
This is my issue. I installed 6000k h.i.d's in my foglights. When i drive with just my fog lights on i have no problem. When i turn my headlights on and have them on together with my foglights, my headlights shut off and on on its own. Then when i leave just my headlights on and my foglights off i dont get that problem. Its just when i have both my headlights and foglights on is that i get that problem that the headlights shut off for like %-8 seconds and they they turn on. It keeps happening as long as i have both my foglights and headlights on. Has anyone experience this problem ? Does anyone know what it might be ? I appreciate any help i can get
i ran across the same problem at first . i noticed on mine that it was the actual light switch . if i just turn the switch to the on position with the switch pulled out for the fogs , it was causing the headlights to turn off on their own . i just move the switch a little bit and they work just fine .
I have 6000k on the bottom and i changed the stock headlights to 6000k bulb. Even with the stock 4300k bulb on there it would do the same thing
Location: Richmond Hill - Markham area, Toronto, Canada
c63, prius
how can u guys install hid fog? because i have a 2010 model and it use H7 bulb, then it plugs in an adapter and convert to 9006 or h11!
