Added BMC air filters & got Engine Light???
'09 C63 AMG
So, I just added a set of BMC air filters and after about 60 miles of driving around today, the engine light appeared on my dash...any ideas? ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Although my car seems to be running perfectly normal, I really don't want to drive around with the engine light on.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I know I installed the BMC air filters correctly and made sure the air box covers were both screwed back on tight with no leaks. I had removed my charcoal filters a while back and never had the engine light come on with the oem stock air filters. I would think the ecu has already adapted to a bit more air coming in to the mix, but do you think the engine light might disappear after some more driving?![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Thanks for your feedback guys!
'09 C63 AMG
'09 C63 AMG
'09 C63 AMG
It's not so much that I'm worried about the CEL (b/c I believe mthis is correct that it's the MAF, and I'm not concerned with the tiny bit of oil on the 2 BMC air filters), but more interested to know if the CEL might disappear on its own? ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
OR should I go to the dealer or somewhere else asap to get the code read and deleted?
I heard that some auto repair shop like Autozone or Pep Boys (or somewhere else?) will read/delete codes @ n/c.
C63 AMG
09 Eurocharged C63 AMG
The CEL will go away on it's own after 18 starts. I have had a random CEL also and it will disappear. Do yourself a favor if you don't notice anything performance change in your car, or awkward noise don't worry about it. These ECU's ,regardless of tuned or untuned, are sensitive and will throw a CEL for the simplest things.
'09 C63 AMG
'09 C63 AMG
Guys the cel for the filters goes away but not for cats that u need a tune for.
The light will go away but it's not good to drive with a hiden cel. U can clear the code u self but star is the onlything that can wipe it out.
My advice go to dealer and have then wipe the cel off. But make sure that's all they do bc they can also wipe u tune. Now that u don't want. Good luck
'09 C63 AMG
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
That is strange that we have guys that pop a CEL once they take out the charcoals or replace with high-flow filters. I have taken mine off and on a few times and so far everything is fine.
'09 C63 AMG
C63AMG
OBDII Reader
Attach the the OBD II tool to the plug in port under the dash and see what code is detected. It may be just a glitch and the reader can reset the trouble code and clear the CEL, positive thoughts!
Some autoparts stores such as Autozone will loan you a reader. Only takes minutes to find out what the situation is.
I got mine from the local Harbor Freight years ago for $39.
ps, I seriously doubt the excessive oil thing on the filters, however, you can buy some MAF sensor cleaner and give them a shot to remove all doubt about contamination from the filters.
http://search.harborfreight.com/cpis...keyword=obd+II
http://cgi.ebay.com/ebaymotors/Launc...item27af1e4a58
'09 C63 AMG
There is a OBDII port right next to the hood release handle under the dash.
May check one out. Thank you!
'09 C63 AMG
Ok guys, the mystery has been solved and the issue is now resolved! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I went to AutoZone and borrowed their code reader. The MAF isn't dirty (from the BMC air filter oil or debris) and there was no problem with my installation of my BMC high-flow air filters.
It was just that the BMC high-flow air filters really do allow higher air flow (which we all knew anyway
); code read AND deleted..."System Too Lean" meaning there's more air in the mix.
My engine light is now off.
I'm hoping the ecu will adapt to the higher air flow if it hasn't already (which I suspect it has since the ecu adapts to changes fairly quickly).
Thank you for all your help gentlemen!
13 Lamborghini SL, 20 Porsche 911 (sold), 09 C63(sold), Vipers (sold)
Glad you got it figured out. Took out my charcoal filters last weekend and will be doing K&N or BMC soon, so wanted to see what happened with your set-up. Any decisions as to why BMC over K&N? Thanks!
'09 C63 AMG
'09 C63 AMG
Update...
The cool front came through last night, so this morning , I had the opportunity to do a couple "spirited" runs on my "private track."
As soon as I mashed the pedal at WOT, I got the engine light again. ![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Although I would hope that this "system too lean" code would eventually stop coming on, I'm ordering an OBD II code reader anyhow so I can just delete the code myself.
