Forgestar Sneak Peak: Something Wicked This Way Comes
#55
2009 C63 AMG, 2009 BMW 328Xi
I took it for a hell run today and the suspension settled down alot....
i`m almost debating the drop now (with qship`s feedback) because it drives so nice with the RE-11`s and the P30 suspension (it`s like they were made for each other)...
but i have the springs in my garage ready to go...
i`m gonna drive it over the weekend and then decide....
the pics are deceptive....it sits lower than it appears...almost no more to go in the rear....
but i still think it needs to be done
![](http://farm5.static.flickr.com/4047/4484855971_62fbf7248c.jpg)
![](http://farm5.static.flickr.com/4059/4484856077_e513386a3c_o.jpg)
![](http://farm5.static.flickr.com/4003/4485506418_8ab0e5f902_o.jpg)
![](http://farm3.static.flickr.com/2801/4484855871_081f5ef0d1_o.jpg)
Car looks great, what size wheels/tires did you go with?
#58
Thanks guys...
The wheels are 19x8.5`s and 19x10`s (ET 50`s in the back)
With Bridgestone RE-11`s - 275-30-19`s out back
The custom paint came out amazing....definitely worth the extra couple of days.......the colour is crazy is the sun...very similar to the colour of the Nissan GT-R wheels
Just need to pull out the D-SLR and get some good shots
![](http://farm3.static.flickr.com/2789/4487125006_8ce64c9472_o.jpg)
#61
You can order the painted to match reflectors from evosport, that's what I did. They fit perfectly and look great. I think about $150 USD. Or you can probably get something off ebay if you want to spend less $$$, but not sure of quality/fit.
#65
Location: Richmond Hill - Markham area, Toronto, Canada
c63, prius
#67
The RE-11 tires are incredible....the combination of the sticky compound and the 275 width make them hook like nails out of the hole....way better ride and performance than the Pirelli`s
Totally recommend them as an upgrade......
The P30 suspension has setlled down even more over the last day and i am really liking the stance (except for the fact that the fronts can be pushed out another 10mm - which would improve both the stance and the front end grip)
I think i`m gonna pull the trigger on some painted markers from Evosport too....(thanks for the reco)
Thanks again for the hook-up! Super happy with the look and weight savings on all 4 corners
![](http://farm5.static.flickr.com/4015/4446043141_0cc0eaf9f1_b.jpg)
#68
EuroCharged 2012 C63 BS Coupè
Well done. +1 on the Re-11's. If I may suggest it.....A set of colour matched lug bolts would be the icing on the cake.
#70
I totally agree with you Barry. The stock lugs are hideous...
Would you happen to know where i could source some (or do you just spray them yourself)
My Audi S8 had black plastic lug caps that just popped ontop of the factory lugs
#71
Forgestars do leave the bolts fairly exposed. There are a few companies that make caps for the bolt heads. Quick google should get you to them. I would try a can of Krylon from CT first....
#72
