C63 AMG (W204) 2008 - 2015
Need help setting up KW V3
Old Apr 15, 2010 | 05:27 PM
aznkuja328's Avatar
12 M156 C204
Cool Need help setting up KW V3
i just got my kw v3 installed on my c63, may i know what are the settings on anyone's kw v3?
actually i am looking for stock non-pp comfort but much better handling and better high speed stability.
please give me some advices because this is my first time using kw v3.
there are too many settings and adjustments which confuse me a lot.
please help, thanks again!
Old Apr 15, 2010 | 06:42 PM
EUGENE-Taiwan's Avatar
Supercharged E92 M3
I helped set up my buddies C63 KW V3!
because the KW is compression and rebound adjustable it can get a little complicated especially when there are not indicators on where you last left off the allen key which is provided.
after riding in the C63 for about 2000kms. My suggestion is go with the middle setting for both compression and rebound.
start by finding out many twist from lowest to highest. so if it takes 4 runs then you would want to stop at the end of the second twist.
Hope this helps!
Old Apr 16, 2010 | 01:35 PM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
I went with the stock (suggested) settings. As of now it's perfect I wouldn't change it even when I track the car.
