C63 AMG (W204) 2008 - 2015
Putting together VOLK order for C63
Old 04-30-2010, 12:10 AM
blackbenzz's Avatar
haters crazy
I haven't received anything yet. Guess you don't want my business
Old 04-30-2010, 10:26 AM
Former Vendor of MBWorld
Staff@RPM's Avatar
Sorry, I left and just checked MBWorld for the first time this morning so I will PM you now.
Old 04-30-2010, 02:10 PM
Staff@RPM's Avatar
OK, I have some more answers for you.
Offsets are going to be 35.
As for the 17" wheels I can do them in 17"x9". I would like to find out what tire you are using with the 17" wheel and we can figure out how aggressive we can go with the fitment.
I will have a listing of available finishes soon and I will share all that information for you too.
Old 04-30-2010, 02:13 PM
Staff@RPM's Avatar
Originally Posted by blindfold
Interested, Pm a price on both size and available finishes please. Also can flat center caps be used on this particular setup?
secondly, what projected sized wheels are recommend on these wheels? Super-Lap version available?
One other question, can the rear possible fit a 10" wheel, I know it's a apples to oranges in terms of fitment but E9x M3's TE37 has an ONE inch increase of wheel width and it would be nice same awesome to have the same width increase for our cars, thanks.
Flat caps will work with the wheels but not the factory caps. I can get you the Super-Lap versions as well, they will also be aggressively priced so I could save you some money with these. I can have Super-Laps by the end of July. I don't know about the 10" wide fitment.
Old 04-30-2010, 02:16 PM
Staff@RPM's Avatar
Originally Posted by HIRO63
You found VR. G2 for C63? I love this one also. I cant find one in Japan that has offset to match C63 with VR.G2. If there is pleasePM me info on this also
I can get you the VR.G2 but it will be 9" in the rear and 8.5" up front.
Old 04-30-2010, 03:11 PM
Super Moderator Alumni
superlubricity's Avatar
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Stock C63 offsets are 18x8 ET45, 18x9 ET54.
Old 04-30-2010, 03:22 PM
  #32
Even Money's Avatar
'15 VW GTI
can you pm me the price on the super laps 18x9.5, 10.5? and the te-37 18x9, 10 formula silver?
is that red sticker optional?
and are the offsets going to be specific to this car as I don't think 35 will work.
Old 04-30-2010, 04:55 PM
  #33
It won't work for the rear on a 9.5" wheel (25mm more aggressive than stock) or 10" wheel (32mm more aggressive than stock).
It may "fit" on a front 8.5" wheel, but it won't be optimal (16mm more aggressive than stock).
Offset Calculator -> http://www.1010tires.com/WheelOffsetCalculator.asp
Old 04-30-2010, 05:15 PM
  #34
Even Money's Avatar
'15 VW GTI
Thanks super...Hopefully these can be special ordered.
Old 04-30-2010, 06:55 PM
  #35
Staff@RPM's Avatar
I'm sorry, 9.5" and 8.5" are available in 40 offset. I can custom order them in any offset and bolt pattern but I need to order 20 sets. If I get orders for 10 sets I would cover the next 10 sets myself. I can't put myself out on 80 VOLK wheels by myself in order to get the hubcentric and custom offset. I will put up the money for 40 of them so if you guys want to get together and we can put a special order in with everything 100% how you would want them. That's the best that I can do.
Old 04-30-2010, 07:03 PM
  #36
8.5" ET40 will work for the front.
9.5" ET40 is still bad for the rear. That's like slapping a 20mm spacer on the stock wheel.
Old 04-30-2010, 07:36 PM
  #37
Boost Gomez's Avatar
C63 AMG
If you've got the ***** for it, it works.
Old 04-30-2010, 07:39 PM
  #38
Staff@RPM's Avatar
If you would like to help put a custom order together and everyone can agree on what they want in there wheel then I am more then open to making it happen for you guys. It's totally up to you.
Let me ask you. What would the ideal offset be for you?
Old 04-30-2010, 07:43 PM
  #39
"Works" is very subjective.
ET40 on a 9.5" wheel sticks out 4mm further than the ET50 10" Forgestar F14.
Old 04-30-2010, 07:50 PM
  #40
Staff@RPM's Avatar
If you guys want to do a custom order I can do 10" rear and I can do it in the SL's which would be the way to go I think. The 19" wheels will be around 18 lbs. and the 18" wheels will be around 17 lbs. The pricing will also be very aggressive on them.
If we decide on 18's
18"x10" 17lbs. each
18"x8.5" 17lbs. each
Price probably less than $3000.00 a set
Old 04-30-2010, 07:54 PM
  #41
Great Question!
  • Something that does not screw with the suspension geometry of the car in a big way.
  • Something that adds a touch of aggressiveness without sticking out too far.
  • Something that allows the use and clearance of 245 front tires / 275 rear tires at any acceptable ride height without the fear of "rubbing".
In my opinion, anything resulting in +7mm to +10mm over stock on a 1/2" larger wheel would be ideal front or rear. (E.g. I have a set of track wheels coming in 8.5" ET44, 9.5" ET53.)
In my opinion, a 10" rear is not needed for our cars.
Old 05-01-2010, 04:00 PM
  #42
dodger63's Avatar
2013 f250 6.7 diesel
Any conclusion on offsets or if were getting a group together to do custom cause I want these yesterday!!!
Old 05-01-2010, 04:30 PM
  #43
C63 AMG
If you can make a custom fitment on the TE37 here are specs I've concluded to be optimal fitment:
19x8.5 ET 43
19x9.5 ET 48
Old 05-01-2010, 05:15 PM
  #44
dodger63's Avatar
So who's in on this? I'm down for 6 wheels 34 more and were good to go!!
Old 05-01-2010, 05:40 PM
  #45
blindfold's Avatar
C63
Anther question is what is the largest sized tires can we fit in the back phyically with any optimal offset, tires size should dictate offset.
Old 05-02-2010, 01:24 AM
  #46
thwalkerjr's Avatar
'09 C63 AMG, '06 CTS-V
Please PM me the price.
18 x 8.5, 18 x 9.5
Quick Reply: Putting together VOLK order for C63
