C63 AMG (W204) 2008 - 2015
Swap-out of OEM gear shifter
Old May 4, 2010 | 06:55 AM
harrower's Avatar
2009 C63, 2007 GL 450
Just a little mod and swapped out the OEM shifter for CF/Alloy AMG shifter. Very simple to do and very cheap to do. What I was amazed at was how cheap the OEM shifter is...all plastic and felt like it was from a Tata or something. I showed the shifter to MB service crew and they even admitted it was a joke. Technican response was "did this really come off a AMG"? Speaks volumes IMHO.
Attached Thumbnails Swap-out of OEM gear shifter-amg-gear-shift.jpg   Swap-out of OEM gear shifter-amg-gear-shift-3.jpg   Swap-out of OEM gear shifter-amg-gear-shift-4.jpg
Old May 4, 2010 | 07:10 AM
sjhugh's Avatar
C63 AMG, BMW 135i
Nice, where did you source the AMG shifter?
Old May 4, 2010 | 07:17 AM
harrower's Avatar
Got it at ForMyMercedes com http://formymercedes.com/mb_results....ry=Shift Knobs
Old May 4, 2010 | 10:25 AM
olszowa12's Avatar
'08 C63 Estate
Looks good Dave - now it's time to install those carbon trims Have you received them already?
I'd go with the carbon gear shifter if the chrome part came in black
Old May 4, 2010 | 10:36 AM
harrower's Avatar
Carbon interior has not arrived yet. Probably 2-3 more weeks to fabricate them. CF steering wheel and CF rear trunk lip have arrived at my office in US so they should be in Europe in a week or so. Will post once installed.
Old May 4, 2010 | 01:07 PM
sflgator's Avatar
'09 C63 AMG
Originally Posted by harrower
Just a little mod and swapped out the OEM shifter for CF/Alloy AMG shifter. Very simple to do and very cheap to do. What I was amazed at was how cheap the OEM shifter is...all plastic and felt like it was from a Tata or something. I showed the shifter to MB here when I took the car into to determine what the bump in rear passenger foot well was and they even admitted it was a joke. Technican response was "did this really come off a AMG"? Speaks volumes IMHO.
I was looking for this...thanks! Still can't understand why MB doesn't have a special ///AMG shifter in the C63 AMG as standard in the first place.
Old May 4, 2010 | 01:17 PM
bhamg's Avatar
C63 AMG
Great find on the knobs! What CF rear lip are you going with?
Old May 4, 2010 | 01:54 PM
harrower's Avatar
I bought one of Gary who sells on the board. This is temp unit as the car is going in for a complete body rework at the end of the summer. Have not decided yet on final body kit but leaning towards Vorsteiner.
Old May 4, 2010 | 02:46 PM
bezita's Avatar
'10 C63, '12 TSX Tech Wagon
Slick looking.... nicely done!!
Old May 4, 2010 | 06:27 PM
PatSC23's Avatar
2009 C63
very nice...opinions with the black maple trim...probably not right?
i went with Gary's CF rear deck lid too
Old May 4, 2010 | 06:36 PM
MNL ICE's Avatar
08 C63 AMG
wow..nice mod
Old May 4, 2010 | 07:11 PM
harrower's Avatar
I think the black maple would look good as well. I considered this option as well, but since I replacing the interior alloy trim with CF and have CF wheel coming as well I went with CF version. The quality was excellent and there was great weight to it. It felt solid alone and feels even better installed. This part reminds of the old MB cars where everything was solid with the highest attention to detail. Just feels right vs. the OEM unit
Old May 4, 2010 | 07:25 PM
callmiro's Avatar
2016 C63 S
Too bad the AMG center doesn't flip up so you can hide the Nitrous button
Looks awesome!
Old May 4, 2010 | 08:06 PM
cek's Avatar
cek
'10 C63 AMG P31, '88 Porsche 911 Carrera Coupe, '78 Toyota FJ40, '10 Audi Q7 TDi
I have this shifter in my car. Talked about it here. Some pics:
Old May 4, 2010 | 09:32 PM
Chris @ GT PRO's Avatar
Former Vendor of MBWorld
C63
looks good Congrats!!!
Old May 5, 2010 | 03:50 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
How do you remove the OEM knob?
Old May 5, 2010 | 03:57 PM
harrower's Avatar
here were instructions I got from their site...followed it and it was very easy
1. The leather boot is stapled to a rectangular plastic frame that slides into the console’s rectangular trim. Remove the boot at the console by slightly pushing in on the leather on the driver’s side approximately 1 inch from the top and bottom. The leather boot will easily slip out of the console.
2. Turn the leather boot inside out. Loosen the first collar by turning counter-clockwise ¼ turn. (Looking at the shift knob from the top with your hand under the boot) Underneath is a second plastic collar which secures four flanges against a groove around the shift rod. These four flanges form the base of the shift knob.
3. This second collar has to be pushed up against the shift knob, away from the flanges in order to loosen the flanges from the groove around the rod. By now you should be able to pull the shift knob, second collar and the shift boot from the shift rod.
4. You still have the shift boot between the base of the shift knob with the 4 flanges and the second collar. There is a small plastic ring that holds the four flanges to the shaft. Turn this ring 1/4 turn counter clockwise to release the fragile flanges from the shaft. By pushing the 4 flanges into the center, towards shift knob, you disengage the collar from the base of the shift knob, and free the boot. To push the 4 flanges into the center, use an 11mm socket attached to an extension. Press the open end of the socket over the flanges to compress them, and simultaneously use a flat blade screwdriver to gently pry the collar from the base of the shift knob.
5. To install the Schaetz shift knob. Unscrew the chrome dome shaped fitting from the base of the shift knob. Place five parts onto the shaft in this order: First put the knurled ring on the shaft, then the nylon ring flat side down, then the leather boot, then the chrome domed fitting, then install the shift knob itself onto the shaft.
Make sure the shift knob is fully seated on the shaft and facing the right direction. Next screw on the chrome dome shaped fitting to the base of the shift knob, which holds the shift knob firmly in place. Next, push the leather boot against the underside of the chrome dome shaped fitting. Bring up the nylon ring against the leather boot. Make sure that the boot is straight and not twisted. Hold boot into position by screwing the knurled ring against the nylon ring. Lastly, re-insert the base of the leather boot into the console’s rectangular trim.
Old May 5, 2010 | 04:26 PM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
Man, that looks really sharp!!!
Old May 5, 2010 | 05:47 PM
sflgator's Avatar
'09 C63 AMG
Just out of curiosity, do you guys have an ///AMG shifter with the black maple trim or just CF?
Old May 5, 2010 | 06:14 PM
harrower's Avatar
CF/Alloy
Old May 5, 2010 | 06:29 PM
cek's Avatar
cek
Black maple. See pics above.
Old May 5, 2010 | 07:35 PM
sflgator's Avatar
'09 C63 AMG
No; that's CF/metal as harrower said.
Old May 5, 2010 | 07:39 PM
Click on the link in the thread -
Old May 5, 2010 | 07:47 PM
sflgator's Avatar
'09 C63 AMG
I don't believe that's the MB black birds eye maple like my car's trim. It looks a bit more brownish, no?
Old May 5, 2010 | 07:58 PM
harrower's Avatar
take a look here. http://schaetztuning.de/shift-knob-r...61552b82b83803 or here http://schaetztuning.de/shift-knob-b...61552b82b83803
These are Schaetz products, but does not have AMG engraving on alloy. None the less a upgrade for sure from the OEM plastic we were all given. Hope this helps
