PCMCIA sd card problems
c63 amg
Hi Guys
As i have the older version, there is no direct ipod connector allowing me to change songs with the console. So as instructed i got a pcmcia card, tried to use a 2gig sd card and it works perfectly...
However after reading the threads, someone suggested the maximum was 16gig, which i purchased, but when loading it, it dosnt work...![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Does anyone know what type of SD card should be used, as my first one was normal SD but the 16g one was SDHC, does that make a difference? or have a loaded too many folders?
Please advise so I can stop burning DVDs
Cheers guys!!!
Cheers guys!!!
Hi Guys
Cheers guys!!!
Cheers guys!!!
I use a 4gb card - it works perfectly and it is almost the same size as a DVD (4.7gb).
You should look at the format type of your 16gb card - whether it is FAT32 or NTFS. It should be formatted to FAT32 I think. Some media readers do not suppoer NTFS. Just right click on the card/drive, press format, and choose FAT32.
Just a suggestion. Not sure whether it will solve the problem. Hope it helps
c63 amg
![Red face](https://mbworld.org/forums/images/icons/icon11.gif)
Just a suggestion. Not sure whether it will solve the problem. Hope it helps![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
thanks buddy
ill give that a try and see how i go!!
appreciate your help
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I believe the comand system is based on WinCE (aka Windows mobile). There are file size limits (I do not remember off the top of my head what they are, but I believe its 4GB per file, and that is a limitation of FAT32). WinCE does not support NTFS, so if you formatted it to that, it won't read. The maximum SD card size that WinCE supports is 32G, so in theory, your 16G card should work.
However, giant caveat here, they come in various names and speeds, but all SD cards are essentially the same, only varying in size and speed, regardless of the name (SDXC SDHC etc) I do not know if the comand system imposes its own limits over those of the underlying OS. Try picking up a number of cheap low capacity SD cards of varying speeds, my guess is that Class 10 (the fastest) my have some compatibility (I had this problem with some readers in older laptops and my work machine) issues, try class 6 or less.
