replacement bulbs for the fog lights. led or not
i'm assuming doing a direct replacement of the H7 bulb with a super white bulb should work fine without any errors. but there were options of 55w and 100w in 6500k. my question is, will the different wattage bulbs shine a different color? and will the 100w even be safe in the fog light assembly?
also, there are some H7 led lights also. and if they happen to work as a direct replacement without throwing codes, will keep them on be ok?
i have very little knowledge when it comes to LEDs except that the LED uses less power i think... but when it comes down to heat/temp, will it be a lot cooler than a regular bulb even though it shines brighter?
Who will have the time to look on the web for it?
