C63 AMG (W204) 2008 - 2015
LAUNCH TECHNIQUE
Old Aug 8, 2010 | 08:26 AM
Leon Bacon's Avatar
From: Southern Maryland, about 50 miles out of D.C.
16 C63S
LAUNCH TECHNIQUE
Any recommendations on best launch technique? Traction control on sport or completely off? Hold revs against brake then feather throttle? Open to suggestions. Also, when in sport mode, I sometimes hit the rev limmiter on full throttle 1-2 shifts, pretty violent. Thoughts?
Thanks.
Leon
Old Aug 8, 2010 | 09:56 AM
AMGTTV8's Avatar
2026 AMG GT63 Pro
shift before you hit redline
Old Aug 8, 2010 | 11:51 AM
no loser's Avatar
c63
First Traction control on sport ( on 2 gear after 4000rpm to 5000 ) the best launch Because some times befor 4000rmp the Traction work
When completely off this is better on gear 1 try to change after 6000rpm or 6500rpm but you have to change faster
( My friend think the better launch for c63 on 2 gear )
I aways using the manual mode Traction control completely off
Try to use always manual mode and you have to know your car when the time to change the gear .
