Ethanol Mix ?
1 Post
2008 C63 AMG
Ethanol Mix ?
I was wondering if any of you may have tried an Ethanol mix in the C63?
Drag cars show huge hp gains, was wondering if it would work on our cars?
I know the Brisk splugs are compatible and I was thinking a mild mix so that the current injectors could handle it.
Any thoughts.
Any thoughts.
scion IQ(five axis), smart fortwo crossblade, austin rover mini
ethanol fuel mix is damaging the mercedes-amg enginess especially those prior of 2003 and older and also cars from 2001-2007. The EPA is now trying to increase ethanol upto 15% or over from cars 2007 and newer. This amount will surely show signs of engine damage.
ethanol is hydrophilic and thereby corrosive to the engine and entire the fuel rail system! one should very rarely ever have to replace a fuel injection system and internal engine parts with low milage.
A hydrophilic membrane will not be fouled or stopped oil, grease or other hydrophobic substances. The membrane is highly attractive to water so the water molecules will push away other molecules in order to gain access to the membrane. Once formed, hydrogen bonds are quite stable and reluctant to break apart.(for the chemist buffs)
everyone needs to muster and contact their necessary representatives and manufacturer's, technician's, etc and put a stop to this ethanol mixture. Or at least many stations that are absolutely free of ethonal!
http://finance.yahoo.com/news/AP-sources-EPA-expected-to-OK-apf-1210895536.html?x=0&sec=topStories&pos=1&asset=&cc ode=
http://www.masterresource.org/2010/08/ethanol-counterattack/
http://www.reporternews.com/news/2010/sep/29/ethanol-in-autos-being-questioned/
http://www.greentechmedia.com/articles/read/tesoro-sues-california-over-ethanol-mandate-1527/
http://www.stateline.org/live/ViewPage.action?siteNodeId=136&languageId=1&conten tId=35692
http://blog.thetruthaboutethanol.org/?p=35
this is what happens when your fuels lines are over time eaten up by ethanol regardless if it is for boats or small engines or etc......
http://www2.tbo.com/content/2009/apr...ne/news-metro/
the key is point is that regardless on what engine vehicle its the resting phase of the engine that causes the damage!
"The problem is that most boats sit for long periods of time without use. When ethanol-blended fuels sit in a gas tank for a long time, the ethanol begins to separate from the gasoline.
When engines consume pure ethanol, a highly corrosive solvent, the results can be disastrous. In addition to unraveling fuel lines, it can loosen sludge, varnish and dirt inside the gas tank, causing fuel lines and carburetors to clog."
"ethanol eats away at the fuel line, causing it to fail, like a collapsing tunnel"
"if water is in the gas tank or engine, the ethanol will separate form the gasoline and bond with the water, that means pumping a mixture of ethanol and water into the engine, if this happens there could be stalling or more jittery engine repsonses....the key is none use of vehicle...the less you use the engine, the more that the ethanol will separate from the gasoline(petrol).
Some people are so dead, they don't vote, they write letters to respective district city or counties officials; they just expect others to fix the fixes. every concerned voice must be heard. but then again most people probably don't have true sports car? this is not about clean energy.
its about corrupted politicians and officials hurting the economy and regular middle class person's. Germany makes some of the most cleanest car--without ethanol! if people don't speak up...soon this country will be deader than dead! All the successful people might just flea due to over-regulation after over regulations.
if nobody takes on these issues what use are these amg engines with out pure petrol!
