MBH Bolt-on system offer
Fingers crossed for Friday next week
Looking at the pictures of MBH's LT's, they will not bolt up to the stock cats because I believe the stock cats (both of them) are connected to the OEM manifold. Once you remove the OEM exhaust manifolds to install the LT's, you are removing the cats. The LT's basically take up the space of where the cats would be.
So, once the MBH LT's are installed, I guess this mid-pipe will bolt up to the open end of the LT's collectors and then to the factory resonator/x-pipe.
I would also like to know if this mid-pipe will bolt up to the stock exhaust manifold and if so, would the secondary cats need to be removed? Could the primary cats be left alone so no O2 code issues and this mid-pipe be installed?
What is the sound difference once installed with factory exhaust manifolds and factory catback? (If this piece can be installed with factory manifolds).
I think I may be a bit confused about this MBH bolt-on mod. Is it just straight pipes that connect to the end of the header collector and then to the factory x-pipe/resonator?
it'll be an alternative to the 2 headers currently on the market (cargraphic and MHP) that i know of that offer a full bolt on solution all the way to the stock resonators and deletes both sets of cats.
http://www.youtube.com/user/hooleybo.../0/TSFe6wbF23Y
Just making sure. btw -- they look great and the car sounds incredible! I'm sure when its on the dyno tomorrow We will shoot some more video. Im expecting the numbers to be in the 450whp range on our dyno dynamics dyno. I bet if we went catless right off the bat, we would see slightly higher than 450whp. Thats my guess right now. I'll know more once its on the dyno tomorrow.
As for pricing, I haven't even thought about that yet. I will be in a production meeting tomorrow and I'm sure we will hash out a reasonable number. While undertaking the the rest of the madness that goes on in our Friday meetings.
