Forgestar F14 wheels - any rubbing on stock suspension?
I'm in the market for some new wheels for my C63 and I like the look of the Forgestar F14's. From other threads, I understand that there can be a wait on these which is fine...
I also noticed that some of the blokes on here complained about rubbing with 275/30/19's on the 19x10 ET50 rear wheels, but they had dropped their cars... If I was going to run the same set-up on stock suspension, should I expect rubbing as well or would there be enough clearance with the stock suspension?
Thanks in advance for any help!
John
This question might sound stupid, but can you explain what everyone is talking about re the wheels not being hubcentric to the c63? Apparently the wheels need different parts to make it fit? Does that reduce the effectiveness/quality of the wheel fitment?
You have to get different lug nuts too as the seat of the Forgestar is different from the factory wheel
what you need are hubcentric rings.. it will center the wheel on the hub.
