Rear diffuser and downforce
Has anyone been able to find real data from wind tunnel testing or from their own real world experience on the improvements in downforce created or reduction in lift of the various diffuser designs out there for the C63? I currently have the Euroteck unit, but still feel that the rear end of the car gets light at 160 - 170 and above. Does the Vorsteiner design offer better high speed stability from reduced lift?
Any thoughts or comments from those who have experimented with different units or have access to wind tunnel testing that may have been performed by the various manufacturers would be appreciated. |
the diffusers for our cars are only for looks, I think... the car need to be low enough(less than 5cm) to have any real ground effect
As far as I know, there is no diffuser out there for the C63 or most other Mercedes that actually is a true functional diffuser. Most diffusers do not create down force, unless it is a true racing diffuser with some sort of wing built into it. Mostly even functional ones only increase high speed stability, and can reduce rear end lift a little bit, but to actually create down force is another thing. If you are truly looking for down force, a large rear wing would help a ton, but then again for the road, it would be quite out of place, a track car, yes, but the wing for you to actually feel down force would sadly make it look like a ricer!:X
The diffuser isnt going to do much for down force.
you want downforce? get this...
https://mbworld.org/forums/attachmen...n-dvc00108.jpg Picture courtesy of forum member: HIRO63 |
Originally Posted by ruthless
(Post 4415329)
https://mbworld.org/forums/attachmen...n-dvc00108.jpg Picture courtesy of forum member: HIRO63 That would really help with down force. |
there is NO "diffuser" on the market for the C63 that provides any downforce whatsoever. In fact, they shouldn't even be referred to as a "diffuser" because it's nothing more than a cosmetic body piece. In fact, due to its design it most likely reduces downforce as it helps reduce drag. If you want more downforce, get a bigger decklid lip like the one Evosport sells for the CLK Black Series.
But be careful...increasing downforce in the rear must be combined with additional downforce up front or else your gonna get some SUPER funky handling above 150mph. |
Originally Posted by LZH
(Post 4415400)
Originally Posted by BlackC230Coupe
(Post 4415032)
Thanks for all the input. I may try a decklid spoiler upgrade like the BOCA Design or the Vorsteiner.
Originally Posted by e1000
(Post 4415444)
Neal your sig is really distracting. :D
sorry guys....i'll change my sig ASAP....
j/k!:rolf: |
(Post 4415444)
Originally Posted by Jae Duk
(Post 4424077)
You know you'd like to test the downforce on that :rolleyes:
(Post 4424714)
wouldn't we all....:rolf:
I wouldn't wanna test just the down force...i wanna test all the forces :rolf: |
Best way to go!!
(Post 4415329)
^^^^^...you betcha...hahaha :y
(Post 4421032)
j/k!:rolf: |
(Post 4425952)
change it to a bigger version!!!!!!!!!
http://img261.imageshack.us/img261/4710/50874510vt7.jpg |
(Post 4426450)
you mean something like this??
You did this to us a couple of years back... :X |
Originally Posted by MB_Forever
(Post 4426459)
God dang it Neal..... not again :D
(Post 4426463)
There you are Mo! Glad I could make you chime in!:rolf::rolf::rolf:
(Post 4426467)
Now you need to post all the high res pictures from that photo-shoot.... yes, again :bow:
http://img261.imageshack.us/img261/6791/11bl1.jpg |
Neal!!!!!!!!!!!!!!!!!! dude e-mail me these pics!! fap fap fap.
(Post 4426918)
(Post 4427206)
hahaha! honestly, the 2 I posted are the best ones, I don't have the Hustler versions YET!:rolf::D:D
