Does anyone know the advantage and disadvantage of new p30/31 rotor
Like most all businesses, we outsource much of our work. We have a full fabrication facility in house, however, for production items, they are sourced out to production houses. One such house is where UUC arrived and asked the owner to take our BMW pulleys and put their name and sell them to him.
As far as the rotors, we do the process in house along with our manufacturer. We examine the vehicle and the available disc options. This is limited by fitment with stock calipers. We then select and machine the rotors and hats and assemble with the highest quality fasteners.
The raw discs that others use, including UUC, may be from the same maker, however, the complete product is not, that I know for certain.
thanks
brad
If you want to talk in more detail please feel free to call me anytime!
Brad
I wonder what they were in my C32. I don't recall a rotor change and they must have happened because the thing has 240,000 miles on it. I think I'd recall a 4,000 brake job.
I would never compromise on brakes, wheels or tires to safe a few dollars.
2. The inward stubs would expand toward the middle, but the rotor, a ring, would expand at a higher rate(it is larger, so it will have more thermal expansion). When a ring under goes thermal expansion, both the inner and outer radii increase. The net affect will be that the stubs will move away from the hat, because the inner radius expands at a greater rate than the stubs. I could not get the file to open for some reason.
3. Yes the deformation of the hat should provide some floating effect.
I would like to make a note that I am note claiming that these work better than a standard two piece floating rotor. I am claiming that they work similarly.
Does anyone know the prices for both old two-piece-rotor and new one?
If both are the same, and new one does not necessarily better than the old two piece one on "performance", why there are more and more car makers use this new rotor?
The old 2 piece rotors are more expensive to manufacture, since more hardware is required and manual labor is involved to assemble them. Also, the old style rotor can be disassembled to change the disc, but the aluminum hat can be re-used. These days everything is about cost cutting, hence the move to the new style rotors.
It will be cheaper for the car manufacturer to buy these hew style rotors from Brembo, but that doesn't mean that they will pass on the savings to you when it's time to exchange them out of warranty
This could be minimun life since I enjoy the mountain route and hit them verd hard! If just for daily drive, three times more than I had is very easy to have!
Rotor, c63 amg, w/amg performance pkg.
08-10 $985.00
and sell it for $738.75.
It is likely MB has upgraded the older rotors to the newer ones and no longer supply the older 2 piece style. I don't know this for sure it is just a guess on my part.
08-10 $985.00
