engine stall during touchless car wash!
Location: Richmond Hill - Markham area, Toronto, Canada
c63, prius
anyone have this experience? i have notice that when car wash machine performing high pressure rinse in the front (grill area), my car will start to rough idle....rpm drop below 500 then stall...when i start the car again....rpm will go above the 500 rpm line a bit..and the needle start going up and down (rough idle)....when i rev the engine once.....everything goes normal again... the only thing i did to the intake is install k&n and remove the extra filter inside the intake box!
it happens to me twice (2 wash) already!
2013 Nissan GT-R BE
This is only a guess, but the high pressure rinse probably created a localize vacuum around the in take, so the engine stall at low rpms. But when you rev the engine, it try to suck more air in and the stall goes away. Just my 2 cents.
Sheep
Sheep
´08 C63 631 rwhp
Same thing happened to me in 2 or 3 washings, i think that the water enter through the intake when existing the high pressure rinse in the front, i suppose that this produce a MAF sensors misreading.
c63, prius
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Its the design of the air intake runners located in the grill, unlike other manufacturers that draw air through the fender well.
Why not turn the engine off until the wash is done? In the brush-less wash here you just sit and wait for it to finish so may as well turn off the engine and avoid the problem.
The manual also recommends putting the climate control on recirculate to avoid getting water in the cabin filter.
c63, prius
I have not personally experienced this phenomena, but I can see this happening due to the placement of the air intakes.
c63, prius
but little bit of water will create some sort of water injection....and it can remove some carbon deposit inside the valvetrain......
