C63 AMG (W204) 2008 - 2015
Okada Plasma Direct?
Old Feb 9, 2011 | 05:58 AM
BO Knows's Avatar
2010 C63, 2007 X5
Anyone have these in their cars? Think it works?
http://cgi.ebay.com/ebaymotors/OKADA...#ht_3525wt_939
Old Feb 9, 2011 | 08:18 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
I've only seen 1 set of this ign , and that was on Hi Boosted M-113 5.5 AMG.
Be Ware of Multi spark ign , Generally leads to a shorter Spark Plug life.
( many sparks per combution event , instead of 1 spark per combustion event) In many cases it will help with a poor combustion Events at Idle & low speed engine operation. Caused by a Large overlap in cam lobe timing, Over octane fuels for engines compression Ratio, and ECU calibration over richness. At hi Rpm, Multi sparks is a NO NO . Just 1 lean Fuel / air mixture & you are buying an 8 pack of pistons. You would be much better off with a IDI spark system.
Cheers _PTEngineering
