O2 sensor gave out after 7,500 miles!!
#51
#54
No problem. I haven't had any problems with Sunoco. Just use the calculator for the desired octane and you should be good. I mix with Shell or Chevron 91.
#55
i have a question....i thought you should only run race/high octane fuel if your car is tuned for it? isnt higher octane fuel harder to burn so if you put it in a car thats not tuned for it, it would actually run worse (since it cant burn all the fuel)...at least thats how i understand it
#57
#59
The only prob with some race fuels is they aren't stoichiometric at the same levels as normal gas.
So for example: vp ms109 is stoichiometric at 13.4:1... If your car is tuned for normal gas which burns at 14.7:1 than you are adding too much air to the mixture and running lean.
So say your tuned for 14 at patial throttle and 13 at WOT, in reality with ms109 you running 15 partial and 14 WOT.
So a good race tune needs to take your fuel source into consideration.
The good thing about mixing ms109 or any higher octane race fuel with regular gas is you increase the octane level so these engines won't detect any knock when your racing and won't pull timing..
#60
hey guys need you'll help... I have a P0056 code and says "O2 sensor bank 2 sensor 2". It all started when I filled my tank with Sams club premium gas. Dumb move of me![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
Is this the right parts? Thanks
http://www.partsgeek.com/catalog/200...ml?brand=bosch
http://www.partsgeek.com/ss/?ssq=W01...&model=C63+AMG
