C63 w/ P31 OE Tuned! Dyno w/ Video!
It has been proven that the P31 was underrated and producing more like 500 crank HP stock putting it side by side with an OE tuned non P31 C63. So with that knowledge many imaged there really couldn't be more more to gain.
Going by this tune and dyno and the statement of how the machine dyno's low your saying your standard tune brings the P31 to 535 crank HP? About 35 more HP than a standard Non P31 tuned C63? Same tune as you put on the Non P31 C63?
Should be putting down some amazing tune only numbers on the 1/4 if they translate to the track... Great..Now we need to add another variable to the records books "Fastest tune only P31"
Looks like the max hp gain for the p31 tune is roughly 6hp over non-p31 tune.
Maybe that's the internals--honestly, 6hp at these levels is basically irrelevant, no?
Just my $.02, but if I had a P31, I would only tune it if I got some headers...in which case I'd have to tune it anyway.
What's interesting, is comparing the orange (xtyper tuned) and aqua blue (DD GT3 RD stock) dyno runs. The dynos suggest a meaningful advantage in HP and TQ, throughout the entire rpm range, for xtyper's car. Yet, head-to-head on the street, they experienced identical performance. Curious.
Going by what DD said in his warning in the OP that this particular dyno reads low and that his baseline is more like 420. So if his baseline is 420 then im just adding the HP he says is lost by the low reading dyno.
The confusion part that im having is Xtypers dyno chart with a tune came in at 420 and DD's at 390ish yet they were side by side on the street. So on one hand DD's can say "Well thats because the dyno reads low" but on other hand that would make Xtypers results low as well...
So something is weird with the data. Why is the baseline P31 coming in so low? If its indeed acurate how did he stay side by side with a tuned non P31 with 30 more rwhp....
Also, still havent gotten an answer on if this is the standard C63 tune or a special tune for the P31. My guess from the lack of response is that this is a "better" tune tailored more for this application.
To much wacky data..... need real word results or both cars on a different dyno on the same day.
we shall find out soon
If you believe the real-world performance on the street, and assuming nearly equivalent weights of both vehicles when they met up... then something's inconsistent with the dyno results.
Either way, sounds like they'll meet up and roll them again in their current state, plus DD mentioned he's going to run some more VBOX runs, so we'll have some more good info to compare soon.
Gotta hand it to these guys, it's great of them to document everything and share it with the forums. Hat's off to them for that.
Is there no-one on this forum that has an "in" with a M.B. Dealer/AMG etc, that can say FACTUALLY, where does the extra power from P31 come from.
I've heard SLS internals, ECU etc etc, but no-one seems to be able to say precisely how the increased power is obtained.
And of course, there are several other 6.3 variants with power going up around 380KW.....well what are the differences there.....camshafts, cylinder heads etc?
I've not had much experience with M.B. stuff, but a bit more with G.M. V8s, where it's common knowledge where the extra power comes from in the various engines.
Cheers, Pickles.
Cheers, Pickles.
Again, I know you've probably heard this and just want the word out of the engineer's mouth. I am happy with what Cory has told me. I don't believe there is any other physical difference in the engines, other than the titanium internals.
They are the same cars, no? Doesn't it all come down to maps in the ECU?
The octane is the same--91 octane.
Cheers, Pickles.
Cheers, Pickles.
), not sure about Xtyper's
