C63 AMG (W204) 2008 - 2015
Traction light on while cornering?
Old Apr 8, 2011 | 09:20 AM
RAW INC's Avatar
cls63
Maybe some who has tracked there car has experienced this and can start me in the right direction. I somewhat understand the light comes on during hard cornering. But i take this corner hard all the time and never had a problem with light ever coming on. I had a strange encounter the first time this happened, car was jerking like some kinda of limp mode, Which i thought was about to put me in the barrier because i was still in the turn. After the pucker factor went away and car went back to normal, i chalked it up to be an uneven part in the road that i couldnt avoid this time. But now the traction light flashes when i pull to the left even in small winding roads.
Old Apr 8, 2011 | 09:56 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
You are, in fact, driving it correctly, lol.
Old Apr 8, 2011 | 10:46 AM
bushburninc63's Avatar
2009 c63, 2010 E63
do you have your traction control turned off? If not it's just the traction control kicking in.
Old Apr 8, 2011 | 11:04 AM
RAW INC's Avatar
cls63
No it wasn't off. just normal conditions. But the problem is, that it is starting to kick in more often on roads that i drive normally. And its never kicked on before.
Old Apr 8, 2011 | 11:16 AM
egauster's Avatar
S550 4matic, ML350
How are your tires? How are any wear items with the suspension? When the light comes on, the wheels are losing grip. This can be hard cornering, uneven roads or soft suspension... if its just coming on driving in a streight line thats something else unless you are on gravel or ice...
Old Apr 8, 2011 | 11:36 AM
RAW INC's Avatar
cls63
[QUOTE=egauster;4614856]How are your tires? How are any wear items with the suspension? When the light comes on, the wheels are losing grip.
They may just be the culprit. I had to run out side to check my tires. I forgot that my car is notorious for tread wear on the inner side making it hard to see. My fronts need to be replaced. Like I'm ordering some now replaced. lol Thanks
