Terminal miss-fire issue....again
Big lesson here is that once you make any visible modifications, be prepared for the dealer to wash their hands of any problems that you may have with the motor and transmission. I knew that going in but I was surprised by their inability to diagnose issues in a modified environment. I am not going to pay MB rates for a blind man to find the problem.
Please keep us posted.
I wonder how having a more efficient exhaust is causing a misfire? I'm not a mechanic, but wouldn't that be on the intake/ignition side of the motor that is causing these issues or a sensor that may affect timing? You still have your O2 sensors, right?
We can do the plugs and coil packs if you want to. They are easy.
No matter the case Jerry will find the culprit.
He knows this motor backwards and forwards and has done the build many times. He's one of the few that knows what he's doing on these cars. If you need any work done I highly recommend him. I know we are in Florida but I know he's already had M156 motors shipped to him for rebuilds so he knows the game. He also knows the trannies and can help there as well.
He custom built the diff cooler for me and has done many of my modifications. For the nitrous build I would recommend Macedo Motorsports. Larry is great with after market stuff. He usually works on Vipers and exotics. Just a plug for my two very hard working mechanics if any of you need a good mechanic to do your stuff!!
Eight new Denso iridiums are on my desk. Perhaps after cars n cafe we could go ahead and change plugs, switch sides on all the coil packs (I also have a tester) and clean the MAF sensors. We could put the car up on Jimmy's rack and visually inspect the o2 sensors as well.
Could you take the exhaust off and put the stock tune on and then go to another dealer?
That would be u best bet for u pocket.
Carful the ethics police are going to hunt you down now...
Sadly im sure they share info and have added the information to his VIN already.
I see both bungs on the MHP headers. It would be great if you can just swap parts with Keith and rule out each item one-by-one rather than play the experimental game with the dealer commiting you to buy each part.
Very sad that the MB tech's were so focused on the modifications that they didn't bother to pop out a plug and take a look. Can you say computer dependant.
Car is GREAT now, likes the Denso plugs and the MHP tune.
Here they are $13.50 each. Every other site was charging $23-$25 per
