What's the real reason why C63 tires wear so fast?
#176
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
You and I are saying exactly the same thing - I was referring to roadtalonsi's statement "its actually in minutes.... so .25 degrees would be 25/60ths of a degree". If it has a decimal point it is indeed in degrees, but 0.25 is NOT 25/60ths of a degree (which would be 25') - it is 25/100ths of a degree, or 15'. If it's in [degrees and] minutes it would be given as [x*] xx'.
I'll second the no math after midnight rule!
Cheers,
Doug
Last edited by Diabolis; 07-16-2013 at 06:06 PM. Reason: no drinking before doing math either
#178
When you dial the rear toe to the factory recommended minimum (or even down to .15), you will have more stability braking in a straight line. There will be less lift throttle or trail braking oversteer (ie lifting throttle or braking into a turn). Your tirewear will improve significantly. The "downside" is that it's easier to get oversteer when you're aggressive on the throttle with ESP off, but it will be more progressive of a slide. ESP sport will catch it fine and pull throttle well before you get into any trouble. Theoretically, at higher speeds, there will be less straight line stability, but I never had the chance to run the car over 200km/h for long periods of time with this setting.
I personally settled for .25 setting for the summer which suited my driving style, and ran .15 in the winter which was magic in terms of freezing weather straight line stability.
#179
sorry im used to using mercedes recommended equipment that always reads in minutes. just trying to clarify things as thats even more misleading if someone is reading '25 and thinking there are 100 units in a degree or didnt know the difference. yes you are correct .25 vs '15 lol. this threads gotten way hardcore technical im somewhat impressed. Keep in mind ride height also determines the specs using the romess gauge. Ill be checking my cars alignment later this week, ill see if the black series specs differ from regular c63. obviously they will some what from sedan to coupe etc...
#181
2001 highlander
Looking at getting a 2011 in the spring and have read this thread. I'm thinking of also adjusting the toe - probably to .30 and getting 265's. I read that with the toe adjusted this way, it will produce oversteer easier, but evenly too, rather than whipping back etc. So my question is, how is this in wetter conditions? Being that it slides easier on dry, i'm sort of assuming it would even slide easier out in the wet?
Is this a dangerous setting... i guess it's in spec so maybe not as bad, but with the wider tires maybe?
looking at the PSS's
#182
Don't turn off ESP and you won't slide (unless you do something really stupid). Simple.
It's only as dangerous as you make it out to be. Drive with ESP off, floor it everywhere without knowing how to handle it, and sure it'll be dangerous.
#183
2001 highlander
So it sounds like then the setting of the toe would be fine even with the slightly wider tires. Thanks... also i decided to go with a 2011 so it would be out of that headbolt thing
