adding an amp question
I haven't seen the wiring but I would like to assume that at least the speakers have conventional wires going to the coil and if that is the case you can do a high input signal converted to low input signal connector(RCA)directly from one of the rear speakers.
As for the use of fiber, that will most likely not be an issue, as the audio from the head unit would be at line level to the stock amp, and then out to the speakers, it makes no sense to use fiber for audio, as audio is analogue, and fiber is digital, so it would require a two DACs to convert from analogue to digital, transmit, digital to analogue. This makes absolutely no sense.
I believe the fiber is communication only, from the various subsystems within the vehicle that communicate with the comand unit.
DOH! LOL, guess I should know my car better than this. Thanks.
and I hope I never do.
