C63 AMG (W204) 2008 - 2015
is there any disadvantage if I put 275 tire on 9' rim?
Old Sep 1, 2011 | 08:24 AM
JeffDL's Avatar
C63
Originally Posted by Dr. Q
hehe.. I will post up.. don't worry about it!!
anyway.. where do u live in MA?
I actually see the same c63 in ur pic near North Quincy..
Just wondering if it's urs..
probably not me I live out in the burbs. work in the burbs. not much of a city go'er.
Old Sep 1, 2011 | 08:39 AM
Dr. Q's Avatar
2009 C63 AMG
Darn it..
Unfortunately.. The rim is still sitting on the caliper after i put the spacer on.... ;(
They r putting my old rims on my car again.. ;(
So sad..
Old Sep 1, 2011 | 09:14 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Sorry to hear Dr Q. U will need larger spacer than 3mm from what I can see.
While they were test fitting the rim with the 3mm spacer, did u check for the clearance between the outer lip & ur fenders to see if u can safely add a thicker spacer? Once again, u can always roll or shave ur fenders if u really want to keep ur 19x10.
Old Sep 1, 2011 | 09:17 AM
Dr. Q's Avatar
2009 C63 AMG
wondering I always have to roll or shave the fenders if I wna keep 19x10?
even w/ different off-set..?
I heard that some ppl have 19x10 w/ no issue..
FYI, now I have HnR springs..
but Im gna get KW V3 coilover sometime soon..
Old Sep 1, 2011 | 09:24 AM
Roswell's Avatar
I have 19x10 with H&R, but my offset is high +53mm. Ur Forgestar offset is too low, so u will have to roll even without spacers. Unless u go stretch tires.
I was hoping to hear u were at stock height.. Now we know u are dropped, it will make it even more tight.
I think James is right, u should go 19x9 in ur situation to clear ur calipers w/o rubbing ur fenders.
