C63 AMG (W204) 2008 - 2015
Installed LED license plate light bulbs and now I have an error code warning?
Old Sep 5, 2011 | 11:17 PM
lyyca's Avatar
C63
I've tried searching and couldn't find anything in regards with this issue. Yesterday I installed the led bulbs and it works just fine. But today I get an error code warning saying that my left license plate light is not working and the lights are working perfectly fine. Is this normal? I understand LED's require less power so I'm guessing the car assumes the light is not working. What do I have to do fix this issue?
Old Sep 5, 2011 | 11:57 PM
bluejae's Avatar
'10 C63
the only way to fix it is to get bulbs that won't give that error... they have to be the correct voltage or something... or have a built in resistor... i believe there's a member on this forum that sells them...
i replaced mine a long time ago and although i get the error on start up, i just exit out of it by pushing the back button a few times...
Old Sep 6, 2011 | 01:41 AM
BO Knows's Avatar
2010 C63, 2007 X5
You got regular LEDs which will give you error codes due to different voltage. Buy LEDs from AZNOptics, best prices and brightest. He's a sponsor here too. https://mbworld.org/forums/c-class-w...ront-w204.html
