Eurocharge V3 TUNE = 540HP??
Happy to report that tonight I ran a 12.39 @ 114 at etown...that's with a crap 2.09 60'.
My best previous stock time was 12.77@113.
Even on street tires I know I can shave a couple tenths off my 60'...with DRs I believe this car will run 11's.
On iPhone now...will post timeslip manana.
Regardless, good job getting out to the track and putting down some numbers.
I agree that my trap should increase more - I believe (hope) that it can I just need more track time to learn how to launch properly.
More testing required and I'll be sure to share when I do.
Launching better will really only help your ET. Your trap speeds are likely valid. You could have a terrible 60', yet still have the trap speed you should expect.
#32
Agreed, and that was exactly my concern. Although more practice will likely improve the ETs a bit, the trap speed shouldn't change much. To me a tuned car should be trapping better than 114mph in decent conditions.
#33
FWIW, I ran my car in S mode. When stock, I alternated runs btwn S and M mode and experienced traps that were about 2MPH faster. What i discovered was S mode = better ETs/lower traps and M mode = higher traps and lower ETs...This was consistent
across every run...any thoughts on why?
#34
Jon's C63 stock was trapping 115 on stock tires. His best trap with an OE tune was 119 on street tires. This is why I say track times show the big picture. 113 is quite low for a 540 HP car. Hopefully we can meet up BK or you come to a track event soon with some DR's. Ill help you get that car dialed in.
#35
I was trapping btwn 111-113 when stock. I'm really want to see if I can pull higher traps because it is a little disappointing to think that the tune hasn't given me the increased performance that I expected.
I'm going back to the track tomorrow to see if my traps improve...if they don't then, I guess I'll know where I stand :-/...fingers crossed.
#36
#39
I agree 113-114mph is STOCK trap speeds. That's what I used to run stock.
Since having put in Renntech stage 2, my trap speed increased to 119mph which is a high 11 second trap.
Also, after putting in the tune, I could spank the M5, which I could never do stock.
Trap speed = king.
Trap speed = king.
