anyone with straight pipes all the way? no x-pipe, no h-pipe
my questions are... does anyone have headers with straight pipes all the way to an after market exhaust system? if so, what's your take on the sound and performance change?
if there isn't anyone with this kind of set up... for those who are more knowledgeable... what would be the pros/cons of going with a straight pipe set up and not having anything connecting either side together... so basically, each side would go straight from the headers all the way out the muffler...
Like bluejae said here are a couple of x-pipes :
MBH -> sponsor http://mbhmotorsports.com/
GT-Pro sold through Ronal Wheels http://www.ronalsales.com/
i'm not trying to argue here... but i'd like to know why adding an x pipe would somehow provide more power and torque for our car? and how dads came about with the decision to go with an x-pipe setup? was it his choice? or was it a suggestion from a tuner? if so, what was the reason behind that?
Its not my preference nor a suggestion from a tuner, its physics. When you bring the two banks together they balance each other. By crossing each other the exhaust pulse from one side helps sucks the next one out the tailpipe thus the scavenging effect. The stock exhaust has a 1/2" H pipe. The peak HP may not improve but the low/midrange torque will and thats what our cars need. Hope that explains it better.
so then if i were to go with a straight pipe set up and replace my stock mufflers and resonators.. i would actually end up losing power compared to my stock mufflers? or would i still gain some but not as much as if i were to have an x or h pipe installed?
I'm not sure what all you plan to replace with straight pipes but be careful, it gets very loud. Most racers are running MHP L/T headers, no cats, with the stock resonators and mufflers.
Also when it comes to x or straight pipe I thought flow balancing really only shows gains after the manifold collectors... so anything far back prob only has min gains. They're commonly used by OE's to quiet a car down a bit... so in that case straight pipe would be cheaper and easier... but im not 100% sure about the sound vs the x-pipe...
I may be off in my thinking, let me know what you guys think?
where is your x-pipe installed? what does it replace
http://www.carcraft.com/techarticles...ion/index.html
Last edited by bluejae; Dec 27, 2011 at 11:13 AM. Reason: found the article i was talking about and made a few corrections
Which one of these is best (quality, sound, etc) or are they both basically the same?
the reason i brought up the akrapovic was that they decided to go straight pipe without some kind of balancer (x or h pipe)...
