C63 AMG (W204) 2008 - 2015
RacingBrake Rotors and Pads available
Old Jan 4, 2012 | 07:17 PM
sales@eurocharged.ca's Avatar
Former Vendor of MBWorld
c63
Go faster with EuroCharged…Stop Quicker with RacingBrake!
REAR ROTORS WITH FUNCTIONAL OEM EMERGENCY BRAKE FUNCTION NOW AVAILABLE FOR ORDER FOR C63!!
Available (all rotors include free rotor shipping to Canada and US 48):
FRONT Two-piece rotor (Open Slot) - C63 AMG 08+
MSRP (each): $704.71
Sale Price (each): $599.00
REAR Two-piece rotor (Open Slot) - C63 AMG 08+
MSRP (each): $823.52
FRONT/REAR SET Two-piece rotor (Open Slot) - C63 AMG 08+
MSRP (4 PIECE SET): $2,396.00
Sale Price (4 PIECE SET): $2149.00
All RB rotors are in stock and ready to ship.
These two-piece rotors were engineered to be the best stock replacement two-piece rotor on the performance market. This rotor is direct bolt-on, easy to install, no additional hardware needed, and an excellent upgrade for both street and track. They can deliver consistent brake torque under extreme heat, session after session. When it comes to replacement - operating cost over time will be lower than the OEM one-piece rotors or two-piece P30/31 (Performance Pack) rotors.
RB rotors are made of harder iron than OE rotors. Our rotors are most compatible with semi-metallic brake pads. We do not recommend the use of ceramic brake pads, which may cause vibration (Judder)
Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated
Machining: Open Slot
Surface: EDP Coating w/cross cut grinding on friction surface
Weight Comparison:
Fronts:
One Piece – 36.0lbs
Two Piece – 24.0lbs
Weight Savings: 12.0 lbs a corner
Rears:
One Piece – 21.5lbs
Two Piece – 15.5lbs
Weight Savings: 6.0 lbs a corner
RacingBrake has been in search of a brake compound that is easy for customers to choose and use. As a result, we have come out with the ET Series brake pads
E = Easy to choose & use
 T = Tough to wear out
ET Series Characteristics
◦ Excellent Modulation
◦ Consistent friction and torque output
◦ Run from ambient temperature (even in cold winter mornings)
◦ Extended life for rotors and pads
◦ Affordable pricing
Application Guide
• ET300
◦ Upgrade from stock pads for higher performance
◦ Excellent initial bite at cold temperature
◦ Very low dust, no squeaking
• ET500
◦ Great for spirited or aggressive street driving
◦ Will not fade under heavy braking
◦ Very low dust, none or occasional squeaking
• ET800
◦ For advanced high speed driving events
◦ Excellent heat characteristics and brake modulation
◦ Occasional squeaking may occur at slow speeds before stopping
Brake Pad (RB ET300) C63 AMG FRONT 08 +
MSRP: $224.00
Sale Price: $190.40
Brake Pad (RB ET500) C63 AMG FRONT 08 +
MSRP: $257.60
Sale Price: $218.96
Brake Pad (RB ET800) C63 AMG FRONT 08 +
MSRP: $296.24
Sale Price: $251.80
North American Orders: Eurocharged Performance- Canada
(855) 258-6666
(416) 457-5505
Attached Thumbnails RacingBrake Rotors and Pads available-img_3877b.jpg   RacingBrake Rotors and Pads available-img_3869b.jpg   RacingBrake Rotors and Pads available-img_3864b.jpg   RacingBrake Rotors and Pads available-img_3858b.jpg
Old Mar 24, 2012 | 01:18 PM
Merc63's Avatar
C63 AMG
What do these rotors weigh compared to the stock 2 piece??
Old Mar 25, 2012 | 08:37 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Hey K.
Front OEM Brake Rotor (2-pc, P30/P31) are 29.6 lbs .
The RacingBrake Fronts are 24.0 lbs each
