Epic Run.. 60-130 in 8.54sec
A Krusty The Clown stop watch of course....
http://vboxusa.com/performancedrift/performancebox.php
Just like any other time or record there will always be variables. Weather is a big factor. The slope is also a factor. The maximum allowed decline is 3% over the distance of the run. Meaning whatever drop in feet divided by the amount of feet it took to complete the run.
If you want to maximize your run you should make sure you are doing everything within the rules to give yourself an advantage. These include the proper slope and choosing good weather. Also making sure your tank is 1/4 or less and your tire pressure is full all around. There are also tricks in shifting that can improve your times as well as a good RPM to begin your run. All these factors depend on the vehicle as well and where it finds it power.
