[Video]: C63 OE-tuned vs C63 Eurocharged tuned
Oh lord...Jon is in all his glory right now lol
Which guys are those on here?? The guys battling with the 60-130 times?
Jon aka Factory Freak vs. BK63AMG.
EC car even got the jump on him...
What else does the OE car have done?
Good race. Pretty much even since Jon in the OE car weighs about 60 pounds less than the other car. Ill race you BK. We weight about the same.
Race seemed to go from 2nd gear just shifting into 5th? This was front page on BB.com right? lol. Funny stuff. I guess Joe needs more drama to keep things moving over there. Been a ghost town since Jon and my 60-130 bs. Im glad Jon found a new c63 to stalk. :) |
Originally Posted by Merc63
(Post 5036685)
OE Tuning FTW!! :bow:
Originally Posted by propain
(Post 5036717)
Originally Posted by BK63amg
(Post 5036614)
Originally Posted by stangxs
(Post 5036686)
(Post 5036717)
Originally Posted by Jons95c36amg
(Post 5036908)
60lbs doesnt equal 1-2mph pull. No he is cool. So I made front page which was a surprise to me.:rolf: Lets all line up 3 lanes. I will record. :naughty:
Nice runs. 60lb's is a bit over 1/2 a car length. It was pretty much an equal race. If you look at the 3rd cars video as you passed you guys were pretty much side by side going into 5th (135) So little difference. The right side view is very deceiving as it exaggerates the distance. I do believe the OE tune is stronger though. :naughty: 3 lane tuned C63 race sounds like fun. :y |
(Post 5036961)
Front page is nothing against you. Its just funny how it was news worthy. Even our 60-130 wasn't. Its just amateur hour on that site.
(Post 5036984)
Dude lets not get into a argument. The EC C63 said he lost by a car to 130. Hmm equal race?
No argument. You won. Nice race. I was simply analyzing the run. You weigh 60 less pounds. That is a factor for sure. You have a P30. Lighter rotors and your car sits lower and has a stiffer racing suspension. Also helps high speed runs. Did you only do 1 run? Do you have any others to share? Surely you cant come to any conclusions with only 1 run? It was way to close. You need to switch lanes at least. Being on the outside has more wind resistance in that spot for sure. At 12 seconds you passed the 3rd car at about 6K RPM in 4th gear. That's about 130. You were not 1 car ahead at that point. Looking at his in car video. It was about 1/2 a car. http://www.youtube.com/watch?v=-Z07-...layer_embedded {BTW pretty dumb having the 3rd car sitting in the outside lane stopped. If BK lost control he would have wrecked into a 4K pound stationary object doing 130 MPH.) You then shifted into 5th and he let off and dropped back. Looked like about 1/2 victory. Maybe 3/4. Hard to tell from your video. |
A car length on a street race is pretty much even. Again, why don't you show up at a track?
(Post 5036995)
EC?
No argument. You won. Nice race. I was simply analyzing the run. You weigh 60 less pounds. That is a factor for sure. You have a P30. Lighter rotors and your car sits lower and has a stiffer racing suspension. Also helps high speed runs. Did you only do 1 run? Do you have any others to share? Surely you cant come to any conclusions with only 1 run? It was way to close. You need to switch lanes at least. Being on the outside has more wind resistance in that spot for sure. At 12 seconds you passed the 3rd car at about 6K RPM in 4th gear. That's about 130. You were not 1 car ahead at that point. Looking at his in car video. It was about 1/2 a car. http://www.youtube.com/watch?v=-Z07-...layer_embedded BTW pretty dumb having the 3rd car sitting in the outside lane stopped. If BK lost control he would have wrecked into a 4K pound stationary object doing 130 MPH. You then shifted into 5th and he let off and dropped back. Looked like about 1/2 victory. Maybe 3/4. Hard to tell from your video. |
(Post 5037004)
Maybe BK63 will say it again. The 2 runs we did he said he lost by a car to 130. Yes its hard to tell from video. Sits lower? He has a front lip which is very low. P30 has 2piece rotors front. One piece rear. Its 6lbs lighter. BUT I also have LSD so its a wash. We both had 1/2 gas.
I'm telling you, everyone needs to bring a 50lb bag of sand when they race you. That's the only way it will be even. LOL Did you have your spare tire removed? |
(Post 5037009)
I believe the P30 sits lower than a standard C63 yes. The P31 does for sure. You have a racing suspension. You also weigh 60 pounds less. Not a wash. You definitely have the weight advantage and the suspension advantage. Even if it doesn't sit lower its still a stiffer racing suspension. Much better for high speeds runs.
(Post 5037019)
You joking? Spare removed?:rolf: LSD adds lbs. Means its a wash for lighter rotors. Also his car sits lower-front lip. Lower than any C63 stock.
Wash for the rotors, not the suspension. Also I still don't see you mentioning your 60 pound advantage. The lip does lower the front end, but not the suspension. Its still helps though. So even if you take away your P30 suspension advantage you still weight 60 less pounds. :) |
Originally Posted by I am Jeff
(Post 5036665)
Jon aka slow c63 vs. BK63AMG.
(Post 5037022)
Yes, spare removed. It takes away another 50+ pounds. What is so funny about this? :confused:
(Post 5037028)
Yes 60lbs less makes a difference. Why would I remove the spare? I dont even remove them at the track.
Otherwise its the same reason why you finally removed your charcoals. To actually start winning some races. :rolf: |
