C63 AMG (W204) 2008 - 2015
Correct Tire Pressure
Old 02-18-2012, 08:49 AM
Pit-Pony's Avatar
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
I know MB recommends tire pressure of 44 & 46 psi but this seems very high compared to most cars.
When the tires get hot this pressure would rise significantly.
For track use, high pressure may be right but for street use this seems awfully high to me.
What are you guys running for pressure to compromise between tire wear and handling on the street?
Old 02-18-2012, 10:09 AM
Even Money's Avatar
'15 VW GTI
Where do you get 44 and 46? IIRC, it's 39 and 41 with just you in the car.
Old 02-18-2012, 10:23 AM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Inside the gas cap. Two sets of numbers. Light load and heavy load. Somewhere between the two is your perfect personal set of numbers. My taught me this.
Wayne
Old 02-18-2012, 10:26 AM
venchka's Avatar
Correction: That should be the inside surface of the gas filler cover door. Open the door like you were filling up the car and you will see the chart.
Wayne
Old 02-18-2012, 12:08 PM
Illusive's Avatar
2012 C63 AMG
I just checked the recommended tire pressure on the inside of the drivers side door, it said 46 and 51psi front and back respectively on the 19" wheels!
PitPony, what TP are you running on the winters?
Old 02-18-2012, 01:00 PM
gthal's Avatar
2012 C63 coupe
I'm running 42 all around. There is a notice on Tirerack that this is the minimum pressure to maintain the load rating. So that is where I set mine. I will adjust for the track when the time comes.
Old 02-18-2012, 03:23 PM
Pit-Pony's Avatar
I'm running 41-42 all around with the winter 225-18".
I'm researching best pressure for the summer 255 & 235 18" for best tire wear on the street.
Old 02-18-2012, 03:25 PM
stangxs's Avatar
c63, 11 e350 (DD)
37-39 here
Old 02-18-2012, 04:02 PM
Pit-Pony's Avatar
On the gas cap lid, MB recommends 41+psi for the winter tire set up.
Old 02-19-2012, 09:03 AM
Firewired's Avatar
M3 - C63 blk/blk ordered
I just picked my car up yesterday and they had the tires set to the recommended pressures. I have read a lot of threads where people have posted running in the high 30's rather than the recommended 40's Could running lower play one part in the quick wear that everyone talks about?
Old 02-20-2012, 12:45 PM
MASTERBENZ's Avatar
Mercedes-Benzes: 2005 ML500, 2002 E320 4-Matic, 1993 300E, 1994 E320, AND 1999 C230 KOMPRESSOR
Always set tire pressure COLD!
Old 02-20-2012, 01:01 PM
rory breaker's Avatar
Yes
Tire pressure from the dealer brand new was 45/46/47PSI all around. Dont remember which was which.
Old 02-20-2012, 01:56 PM
derek's Avatar
A couple of fast cars.
40 all around.
Old 02-20-2012, 09:23 PM
_AMG_'s Avatar
C63
I'm running 38 psi all around.
I have 19" wheels though. Dunno if that makes a difference or not.
Old 02-20-2012, 09:30 PM
mthis's Avatar
Anything W/4Wheels
Originally Posted by stangxs
37-39 here
Lol 35-35here But it grips.
(cold)
Old 02-21-2012, 08:33 AM
Pit-Pony's Avatar
So, we are all over the place. Situation normal
emazens (05-17-2023)
Old 02-21-2012, 08:34 AM
venchka's Avatar
Cool
Aye. Never have so many said so much about so little. This is worse than the never ending question of which B&W film developer to use. Ask 100 people and get 200+ answers.
Wayne
Old 02-21-2012, 05:17 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
I just installed new tires and i noticed that I kept losing air. Took it to the dealer and he filled all four to 40. I just checked three hours later and both back tires went down to 33. I took it to a shop and they said the tire sensors are leaking the air. I have not hit any pot holes or bumps and I've only had them on for about a month. The guy told me maybe while they were being mounted to the rim, he messed my sensors up. Sorry to jack the thread but I need some help
Old 02-21-2012, 05:48 PM
rbdett's Avatar
c63
ok
ok so what it the psi again
Old 02-21-2012, 07:01 PM
Even Money's Avatar
'15 VW GTI
U guys make this way too hard. Read the manual, take it to the dealer, problem solved. Or call your SA and ask what the psi should be if you can't read off the gas cap.
Old 02-21-2012, 10:57 PM
Pit-Pony's Avatar
All MB SE will tell you is to follow what's on the car label drivers door/gas door.
It may be better to use less pressure though.
I'm asking for people's experience for making the tires last and a compromise street performance.
Old 02-21-2012, 11:32 PM
bhamg's Avatar
C63 AMG
This has been covered many times in the past but a certain number of us use pressures in the 36-38psi range. I do, for the best combination of handling, ride comfort and even wear across the tread. YMMV.
Old 11-17-2012, 03:07 PM
Dogtag114's Avatar
2009 c63
OK. So I took off the Pirelli's I burned up in 6000 miles and the wear definitely looks like overinflation on the rears.
I was running at 38 or so on the 18" OEMs.
The new PSS's are going on now and they said to keep them at 34 or so.
Is this too low? It looks like everyone has an opinion, but I know there are a lot of PSS lovers here.
Old 11-17-2012, 03:47 PM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question
Definitely too low....IMHO.
Don't forget you're running low profile rubber, & with that low pressure, you are lessening the "cushioning" barrier that you need to protect your rims if you hit a rock or something.....you are more likely to suffer tyre damage which can then more easily transmit to the rim....I'd be going a MINIMUM of 38.
Cheers, Pickles.
Old 11-17-2012, 04:08 PM
gthal's Avatar
2012 C63 coupe
I definitely agree with Pickles... 34 is too low. Anything less than 42 and Tire Rack told me they no longer have the same load rating and it is too low for the car. I run 42 all around and my PSS wore perfectly evenly... outside measured within 1/32nd of the middle on all 4 tires (this included a couple of track days). I would bet 34 and the outsides wear horribly. I also found anything below 40 and the tire felt sloppy and the sides rolled.
Quick Reply: Correct Tire Pressure
